Make2D and project units
All  1-2  3-9
6573.3 In reply to 6573.2
Yes, the scale of some objects does indeed go lower than 0.01 meters.
Thank you Michael, I would really appreciate that!
m.
6573.4 In reply to 6573.3
Hi Max,
The update helps make tolerances to be relative to the overall size of the stuff being processed, so it will probably help with that although if you still have objects very much larger than that being processed for the same export that can still be a problem.
6573.5 In reply to 6573.4
That should at least improve the result!
Anyways, is there any way to manually set the tolerance?
Looking forward to give it a try soon.
M.
6573.6 In reply to 6573.5
Hi Max,
No, not currently. It will be automatically calculated as a fraction of the overall size of the stuff being processed with the next beta.
6573.7 In reply to 6573.6
Thank you for your prompt replies. Best wishes!
6573.8
Sorry for my stupid question,
what is Make2D, I haven´t seen it yet.
Rudl
6573.9 In reply to 6573.8
Hi Rudl,
It's a new command added in the last beta, which basically does the same thing as saving to PDF format but just generates those curves inside of MoI rather than writing them to a file.
To use it you need to set up a shortcut key and put in Make2D as the command name.
Show messages: All  1-2  3-9
