How to join the edges of 2 surfaces?
654.1
Hi everybody,
I wanted to join the edges of 2 surfaces. Didn“t for some reason not achieve succes with "merge".
Any suggestions?
Thanx in advance,
Boatstalker
654.2 In reply to 654.1
Hi Boatstalker - try selecting the 2 surfaces and use Edit / Join. If the surfaces are running alongside each other that should join them together into one object.
If that doesn't work, can you please post a .3dm file with your objects so I can take a better look at what is going on?
I can see how the name could lead you astray, but "merge" is slightly different - it's more for intersecting 2 objects and then extracting out all the volumes that are formed. Kind of like boolean difference, but it keeps everything instead of throwing away any pieces.
654.3
Thanx Michael.
P.s. those Boolean operations are just wonderful:-)
Best regards,
Boatstalker
