Trial mode, can't fillet a curved circle splitted in 4 parts
All  1-5  6-15
Seems Extrude is perfect for that! ;)
And you can Boolean Union at the end depending of what do you want! :)
6532.7 In reply to 6532.6
great
bolean union?
a screenshot of the effect?
by the way, I'm loving Moi 3D
I can do things that are not possible in sketchup
6532.8 In reply to 6532.7
You can make Boolean Diff, Union, Intersect...between volumes with Moi!
It's one the caracteristic principal of the Nurbs program!
Menu Construct / Boolean / Union
http://moi3d.com/2.0/docs/moi_command_reference7.htm#Construct_Boolean
EDITED: 25 Feb 2014 by PILOU
6532.9 In reply to 6532.8
yes I know, but I still cant merge the 2 complanar circles... I'm too used to sketchup,
so, same plane, delete the lines.... not here ;-)
still unable to merge...
and also, I found that when I use extrude, it creates a new surface above, so it's not the same as moving a surface :-S
EDITED: 25 Feb 2014 by SALAMALA
6532.10 In reply to 6532.9
Maybe you can also make a Scale 1D depending of the object
You must forget Polygon method of modelisation!
Ps You can make the same boolean with Sketchup with the Pro Version (or Free with Colean plugin ;)
but with powerless and preciseless than Moi ! :)
6532.11 In reply to 6532.10
I see..
thank you
but still here, and cant join those 2 faces
Depending if you want just the external view of your object
6532.13 In reply to 6532.12
great thank you
I think I have to watch hours of tutorials to learn how it works this fantastic software
6532.14 In reply to 6532.13
If you speak French you can find some numerous videos here! ;)
http://moiscript.weebly.com/
6532.15 In reply to 6532.5
Hi salamala,
> Now I'm trying to pull out a plane....it's not so intuitive... do I have to select the plane or the edges?
> how can I move it?
It sounds like you've got this figured out already, but in MoI there is not currently any method for moving an individual face. That is something that I want to add in the future but for now to get the same effect you would make an extrusion from that face and then use a boolean to either add or subtract it from the base object.
See here for how to do things similar to SketchUp:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2215.7
MoI operates in a somewhat different way from SketchUp, but one big advantage with MoI is that you're able to work with actual curves and curved surfaces instead of only flat polygons.
Show messages: All  1-5  6-15
