From time to time, it appeared useful for me to have a command for copying
a selected objects to existing set of points - particularly in conjunction with Isect (Intersect) and Array command.
So I have made it...
Unzip the file CopyToPoints.zip into the \commands folder (e.g. C:\Program Files\MoI beta Apr-26-2007\commands)
Go to your moi.ini and add a keyboard shortcut, for example:
[Shortcut Keys]
Alt+P=CopyToPoints
There is only one difference in comparison with regular Copy command.
You must select a target points instead of picking the ones.
If you check the "Delete points" option, the target points will be deleted.
For selecting a target points, you can set a keyboard shortcut to select all points in the scene:
Ctrl+P=script:moi.geometryDatabase.getObjects().getPoints().setProperty( 'selected', true );
or just select all objects by typing Ctrl+A or clicking SelectAll button and command "extract" all points itself.
Enjoy yourself :)
Petr
ps: oh, so much post to read... hehe..
