help on thickness
All  1-6  7-12
6523.7 In reply to 6523.6
Hi Monica, the problem there looks like your main object was not a fully closed solid when you cut it - a cutting object will only leave its impression on an object sealing it up when that original object is a completely closed solid volume. If the object is an open surface it will just cut the surfaces and not know how to make the result a solid.
It looks like possibly some areas of your current model do not meet up quite close enough to join together to make a solid, I'll investigate it a little bit to see what might be wrong.
6523.8 In reply to 6523.6
Hi Monica, so the problem seems to be in this area here:
The surfaces are not joined together in that area, that's what is preventing your object here from being a solid. They seem to be close enough together that they ought to join but they are not doing it, I guess it must be some bug in the joining mechanism which I have not come across before. I'll see if possibly reconstructing those to the exact same curve might help.
6523.9 In reply to 6523.1
Hi Monica - deleting the top planar face and then reconstructing it by selecting the existing edge curves and running Construct > Planar seems to solve the joining problem.
But it would be easier to finish up the model if it was in the pre-boolean state before the hole was opened up in the side. Do you have a version of this file saved off before it was cut by the circle? If so please post that one so I can repair that version and then the boolean with the circle cut should work properly after that.
6523.10 In reply to 6523.9
Hi Monica, never mind about the other pre-booleaned version, I was able to repair your file and fill in the hole, I've attached the result here.
I'm not sure why your original one did not join together properly - looks like some sort of bug in the geometry library. But at any rate I was able to get that problem area joined by deleting the top planar face and constructing a new one in place of it. The new one then joined in ok with the side wall pieces.
Then to fill in the hole area I extruded up a circle from and trimmed it, and then used Join to join those pieces together to make a finished solid, it should now work ok for STL export.
6523.11 In reply to 6523.10
Ciao Monica
posta sempre anche le curve che usi per costruire l'oggetto,inclusa la curva di taglio laterale, ed assegna loro un nome cosi' sono visibili nel browser
organizza bene il disegno dall'inizio:
spline inferiore
spline superiore
offset spline inferiore
offset spline superiore
spline di taglio
vaso (il solido a cui darai un nome)
cosi' è molto piu' facile aiutarti in quanto ci stanno tutte le curve che hai usato per costruire il tuo vaso
regola generale:
evitare SEMPRE spigoli troppo acuti e affilati(problemi nel FILLET...)
usare,se possibile,SEMPRE pochi punti per le spline-profilo..altrimenti usa il comando REBUILD per ricostruire e redistribuire uniformemente i punti lungo la spline
se vuoi,ri-posta il file con tutte le curve che hai usato,cosi mi è piu' semplice spiegarti,senno' ricordatelo per la prossima volta
Mauro
I have translated to help better Monica and better for me to explain
I suggest her to post also splines she use to build the object,and give a name for each curve so it will visible on the browser
much more easy for people want to have a look and suggest techniques
also keep splines with less points or use REBUILD command to have more uniform point's distribution
6523.12 In reply to 6523.11
Thank you Michael e Grazie a Mauro.
I made it! Indeed it was a matter of joining the pieces at each major step and at the end "union"izing them to get a solid.
Price for 3DP ceramics is still too high, but making it smaller won't make sense as it gets too deformed.
Thank you for the advices.
I thought the splines were in my attachment as hidden curves.
I'll be more attentive next time
Enjoy your Sunday
Monica
PS: apology for lack of accuracy in my wording ........but 3 months ago I didn't know the meaning of extrude and fillet.
Show messages: All  1-6  7-12
