PDF Export Question - Page Size
All  1-2  3-5
6522.3 In reply to 6522.2
Thanks for the prompt reply. That is what I assumed, but figured I would ask.
6522.4 In reply to 6522.1
Also I think it may be possible to directly edit the pdf in a text editor to change the page size how you need it.
If you open the PDF file up in notepad, search for: MediaBox[ 0.000000 0.000000 612.000000 792.000000] - that's what actually defines the page size.
Those are in "points" units where 1 point = 1/72 of an inch. So for a 18" x 32" page you want that to say: MediaBox[ 0.000000 0.000000 1296.000000 2304.000000] - that's 18 * 72 and 32 * 72.
Some areas of a PDF file can't be edited with new inserted digits like that because some things are based on byte offsets from the start of the file. But for this particular thing I think it comes after all that type of stuff so I think this particular direct edit should work, it seems to be ok over here. It might not be a bad idea to slice off one of the trailing zeros after the decimal point for those 2 edited values so the file byte length stays the same.
Anyway that could be another alternative to using Illustrator for the time being.
6522.5 In reply to 6522.1
There's also a command line utility program here which can edit the page size:
http://podofo.sourceforge.net/tools.html
It's the podofobox utility there, an example of using it here:
http://stackoverflow.com/questions/5307825/how-to-crop-pdf-margins-using-pdftk-and-mediabox
Show messages: All  1-2  3-5
