Enneper Surface Script
 1-8  9-28  29-38
6521.9 In reply to 6521.1
First of all thank you for your fantastic contributions, simply great !
I tried to install the rhino math plugin,, download link:
http://rhino3.de/_develop/__v3_plugins/math/MathForV5.zip
but unfortunately the math library is missing
and may be that also the VBscript libraries are missing ?
I am wondering if you happen to know another source to download?
Very many thanks,
Ken
Here is a draft script of the Richmond surface, which has Enneper end near the center, and Planar end at the periphery.
Order can be increased for more ruffles.
Additional description is in the .js file.
6521.11 In reply to 6521.10
Have not been at the forum for a couple of days and coming back - guess what - just discovered that bemfarmer has
come up with a new script !! Awesome Sunday surprise. And THANK YOU so much Mr bemfarmer for wiring up
this nice little tool - I am amazed.
6521.12 In reply to 6521.11
Hi.
The enneper script by default generates curves with dimensions between 0 and around 3mm.
I create lofts from them and these surfaces should fit with others of much larger scale (between 30
and 100 mm) So it would make work more fluid if I were able to create the enneper curves at
a bigger / chosen scale. (increasing the "max" value wont help as this drastically changes the shape
of the generated curve. My question here is :
What do I have to insert in the script to create curves with a bigger radius, example 100 mm ?
EDITED: 2 Jun 2016 by SIRTOM
6521.13 In reply to 6521.12
Tom,
Not sure if this helps, but attached is a very simple .nod file
for enneper generation that can be scaled.
-James
EDITED: 14 May 2019 by JFH
6521.14 In reply to 6521.13
Hi James,
Thank's a lot!
How much can be eclectic the MathArray Node made by Max ?!!
It would be fantastic if almost every plugin written until now for Moi,
could be rewritten for NodeEditor!!!
Nice day,
Marco (mkdm).
6521.15 In reply to 6521.13
Thankyou James. Does the Nodeeitor work for V2 ?
6521.16 In reply to 6521.15
Tom,
I don't know, I'm using V3.
I can't see why it wouldn't.
Give it a go, it's great fun.
Good Luck
-James
6521.17 In reply to 6521.16
Looks like an amazing tool - will have a look and hope to find instructions
About the Node Enneper : Maybe you must limit number of Lobes to 12!
It's freezes and blocks Moi over 12 ! (in reasonable time)
EDITED: 2 Jun 2016 by PILOU
6521.19 In reply to 6521.18
No nodes possible in V2. Thinking about transition to V3 but there are
still lots of secrets for me to unpack in V2 before getting to know all
the new treasures hidden in V3.
6521.20
Hi.
The Enneper script generates curveswith very small dimensions around 1,5 mm.
Is there a way to change some numbers in the script to be able to generate curves with much larger dimension - I am currently curves with MaxRadiis around 170mm.
I achieve this by scaling, of cours, bur would be very helpful toe get the desired size directtly.
TOM
6521.21 In reply to 6521.20
Since MoI does Scale, I usually do not put in a scale.
Here is a version with a built in scale multiplier.
The enneper curves, depending upon settings, have about 2 orders of magnitude already. (???)
Attachment revised 9/28/2017, with Update error and Scaling error fixed.
See corrected script, post 25 below.
EDITED: 28 Sep 2017 by BEMFARMER
6521.22 In reply to 6521.21
Hey Brian thank you - thats awesome !
I may be doing something wrong as I am getting different curves
with the two scripts using the same values - see attached file.
White _
Originale Enneper script
lobes 5 Max Radius 1,15 - then scaled manually
Red
New Enneper script
lobes 5 Max Radius 1,15 -scaled with slider
6521.23 In reply to 6521.22
Hi Tom,
That is amazing!
So my thinking must be faulty, applying scale to points. I'll have to think on it some more...
Message 6521.24 deleted 28 Sep 2017 by BEMFARMER
So the problem is a very simple error, failing to place parenthesis around the equations for x and y, so that the scale applies to the whole line.
(z was correct as there was no addition, so the curves changed shape.)
Script updated again with scaling error corrected. Updating also is corrected.
6521.26 In reply to 6521.25
Thats it - works perfectly.
HUGE THANKS !!!
6521.27
I tried out the Ennepernode but ist does not run.
What I relalizeid ist that the node named "convert array" displays Points and Objects" whereas in the JPG posted by James the same node displays "In and Out."
An thought what I could do to get it running ?
6521.28 In reply to 6521.27
Hi Tom,
The enneper array is working here, in both MoI3 and MoI4Beta.
Maybe install Jame's latest nodeeditor extensions?
I do not understand your sentence with convert array/Points and Objects/In and Out.
Show messages:  1-8  9-28  29-38
