Enneper Surface Script
 1-11  12-31  32-38
Message 6521.32 deleted 25 Jun 2019 by JFH
6521.33 In reply to 6521.32
Thats terrific James, thank you ! I had a look at your gallery and
am amazed about your Nodeology-skills. Do you have any background
in programming / math ?
Is there a thread collecting all the nodes available. I will have a look
at the simpler ones to understand how the system works.
As nothing seems impossible I am speculating if it would be possible
to also change the radius values of an Enneper with sliders.
PS The attachment was a scrrenshot of the node which does not work because
as you said ""MathArray" was superseded by "MathsPts"
6521.34 In reply to 6521.33
Tom,
OK, I've added Umin and Umax sliders which should do what you want.
>> Do you have any background in programming / math ? <<
A programming background would be beneficial, but not necessary (I'm not a programmer).
As far as maths go, some high school level trigonometry is really all you need.
.>> Is there a thread collecting all the nodes available. <<
"Nodebundle for playing with nodes" thread charts the development of NE, but also my own skill acquisition. If you look at my early thread posts, the examples are very rudimentary and become more sophisticated painstakingly over time.
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1
My best advice, if you want to learn NE, is to be persistent. Sometimes you find yourself at a dead-end, take a different tack, and just keep going.
Good luck
6521.35 In reply to 6521.34
<< if you want to learn NE, is to be persistent
When you say that :
- it's for make something with NE ?
- program something for NE ?
- just use a nod existing ?
Do you always update this thread ? http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.1
with Enneper Surface above! ;)
EDITED: 25 Jun 2019 by PILOU
6521.36 In reply to 6521.35
option (d) All of the above.....& in life, generally :)
Although it would be a serviceable philosophy of life, I meant specifically generating something in NE.
>> Do you always update this thread ? <<
Yes I will include any new node or changes. The nodeEditor folder here will be the same as I am using on my computer.
BTW Cool Image!
6521.37 In reply to 6521.36
Perfect! :)
EDITED: 26 Jun 2019 by PILOU
6521.38 In reply to 6521.34
Thats it - fantastic ! Thank you so much James for helping out.
I would not have figured out how to get it done by myself.
Good to know that node-sorcery is available for people without
extensive programming or math background. As in any field,
mastery, I believe you, will be only accessible with lots of practice
- and pain :-)
Thank you again, very happy with your perfect noe :-) TOM
Show messages:  1-11  12-31  32-38
