Dashed curve
All  1-6  7-15
6518.7 In reply to 6518.5
You can also use the Flow technique to make a customized dash shape by making whatever you want for the base straight pattern.
This is kind of like a chain script, with dashes instead of links.
6518.9
Will try your sugestion, it looks a better way to do it.
Thanks for your help.
Carlos
6518.10
Hello,
After digging on Illustrator forums found that is possible to do it in Illustrator (CC at least).
Draw a dashed line > Select line > Object > Flatten Trnasparency > UnGroup > Coumpound Path > Release
This work for me, hope its usefull to someone.
Carlos
6518.11 In reply to 6518.10
Hi Carlos,
Not so long ago I wrote a script which can help you.
PatternSelection.
This script not always works good, but in your particular case it can be very helpful.
Usage: Select objects. Run script. Define a selection pattern (by using "+" "-" or "1" "0" symbols)
This video shows how it works.
EDITED: 7 Mar 2022 by SMIRNOV
6518.12
Hi Max,
That is exactly what i was looking for, its great. Thanks a lot.
Now i dont need to leave Moi to finish this task. Well done, Max.
Carlos
Funny script! :)
EDITED: 20 Feb 2014 by PILOU
6518.14 In reply to 6518.13
Yes, you can use any symbol to deselect an object, not only "0" or "-" :)
Test the new version.
6518.15 In reply to 6518.14
Funny I just post the French tutorial version ! (not the translation because there an only one word Pattern! :)
Seems your last works fine!
http://moiscript.weebly.com/scripts-de-max-smirnov.html
Show messages: All  1-6  7-15
