Dashed curve
All  1-4  5-15
6518.5
I'm using a plotter with a cutting blade.
Yes, i'm aware that i could change the line type on Illustrator CC, but this plotter 'transform' any line type on regular lines, as this plotter is very old and its software very arcaic, so i often need really small curves with small gaps from each other so the plotter can make a dashed cut.
I bring this up hoping if there's a better way, or a script i missed.
Maybe its time to start saving for a new plotter : )
Carlos
6518.6 In reply to 6518.5
Hi Carlos, probably the easiest way then would be to assemble your segments in a straight line by drawing one small segment and using Transform > Array > Dir to replicate that into your desired pattern.
Then once you have a bunch of straight line segments, draw another line running the entire length. Then select all the small segments (you can do 1 or 2 strategic window selections to get them all and not the long backbone line, by using the start-on-left and drag-to-right kind of window that only captures things entirely inside of it), and run Transform > Deform > Flow. Then select the long backbone line that runs the entire length of the pieces as the base curve, and your bendy curve as the target curve and that should place all your segments onto the bendy curve.
I've attached an example, in this example I've made the dashed lines slightly offset from the backbone curve just so you can see how they are configured, in your real case you'd probably want the backbone line to run right down the middle of the straight dashed ones so they will fall directly on the bendy one rather than offset to one side of it:
Hope that might make things easier for you!
6518.7 In reply to 6518.5
You can also use the Flow technique to make a customized dash shape by making whatever you want for the base straight pattern.
This is kind of like a chain script, with dashes instead of links.
6518.9
Will try your sugestion, it looks a better way to do it.
Thanks for your help.
Carlos
6518.10
Hello,
After digging on Illustrator forums found that is possible to do it in Illustrator (CC at least).
Draw a dashed line > Select line > Object > Flatten Trnasparency > UnGroup > Coumpound Path > Release
This work for me, hope its usefull to someone.
Carlos
6518.11 In reply to 6518.10
Hi Carlos,
Not so long ago I wrote a script which can help you.
PatternSelection.
This script not always works good, but in your particular case it can be very helpful.
Usage: Select objects. Run script. Define a selection pattern (by using "+" "-" or "1" "0" symbols)
This video shows how it works.
EDITED: 7 Mar 2022 by SMIRNOV
6518.12
Hi Max,
That is exactly what i was looking for, its great. Thanks a lot.
Now i dont need to leave Moi to finish this task. Well done, Max.
Carlos
Funny script! :)
EDITED: 20 Feb 2014 by PILOU
6518.14 In reply to 6518.13
Yes, you can use any symbol to deselect an object, not only "0" or "-" :)
Test the new version.
6518.15 In reply to 6518.14
Funny I just post the French tutorial version ! (not the translation because there an only one word Pattern! :)
Seems your last works fine!
http://moiscript.weebly.com/scripts-de-max-smirnov.html
Show messages: All  1-4  5-15
