Cloth simulation
 1-6  7-26  27-46  47-66  67-73
6514.47 In reply to 6514.46
Cool! :-)
6514.48 In reply to 6514.46
Nice to see cloth simulation outside Cinema4D as well. :-)
Peace,
Rich_Art. ;-)
6514.49
The new version (v0.95). Even earlier than planned :)
[added] three different types of constraints ( version 0.8 - one type )
[added] flexibility control
[added] increased precision of the cloth structure calculation ( upto 20 iterations per frame. version 0.8 - one iteration)
[added] Frame skipping slider (allows to skip frame updating during calculations)
I know about this problem. I'll try to fix it in the next version.
Update (v0.96):
[added] Lock anchor points checkbox (the problem described above is partially solved)
EDITED: 7 Mar 2022 by SMIRNOV
6514.50 In reply to 6514.49
Very convincing result!
Seems this always only spheres ?
But seems you have had some parameters! :)
EDITED: 21 Feb 2014 by PILOU
6514.51 In reply to 6514.50
At this moment only spheres and donuts :)).. But I plan to add a new obstacle type - triangles. :)
6514.52 In reply to 6514.51
Seems donut's don't stop cloth! ( a circle sweeping on a circle)
French Version :) http://moiscript.weebly.com/simulation-tissu.html
6514.53 In reply to 6514.52
Hint: you can use more than one sphere :)
Use spheres to build a donut.
P.S. Thank you very much for the translation. But you definitly need to enlarge sliders. It's impossible to use the script with such small sliders.
6514.54 In reply to 6514.53
Ah ok for the trick of the donuts :)
<< But you definitly need to enlarge sliders.
Seems sufficient as you can enter any number on the right's case! :)
And in French words are often more longer than English!
PS What render do you use for your gorgeous images ?
Pss Seems I have a problem!
Gride is exploded when arrive on the spheres!
In fact Spheres were not enough big but curious as they were more bigest than a square of the gride!
Seems sphere must be twice bigger than a "square" of the gride ?
Here gride passes away but the square is smaller than the sphere!
here that works because spheres are biggest :)
Possibilities are endless! :)
(cool your CommandBar Lighting + Dinos for put some car plastic lights! :)
6514.55 In reply to 6514.54
Hi Pilou
Not any number. Constraints settings can be changed with sliders only.
Octane render (http://render.otoy.com/)
It depends of Timestep value.
Also you can try to increase Shear value to reduce flexibility.
6514.56 In reply to 6514.55
<< Constraints settings can be changed with sliders only.
Ah, yes you can enter number but you have put some maximum! :)
<< It depends of Timestep value.
So if time is not a good value gride can pass away even it's a little gride! :)
Some analogy with this one! ;)
6514.58
top work Max need to have a play with the scripts :)
6514.59 In reply to 6514.57
cool..
Peace,
Rich_Art. ;-)
6514.60 In reply to 6514.47
Hi Max,
Have you updated this script since 20 Feb 2014 ?
thanks
6514.61
Really beautiful work Max!
Do you think a reverse-action version of this script could be applied to the scenario of flattening (un-forming / developing) a sheet metal blank that has been pressed over a form block?
- Hamish
6514.62
Finema
Sorry. No. I haven't any plan to improve this script. Maybe later.
Hamish
Thank you :)
Yes, it can be done for a bended or folded surfaces. But not for pressed.
6514.63 In reply to 6514.62
Thanks Max.
6514.64
A really cool script Max.
I had some fun with it.
This is what I came up with in a few minutes.
Just wanted to share.
Thank you
6514.65 In reply to 6514.26
Sorry for this stupid question,
but my moi3D interface does not have the icons at the bottom : nothing between snaps and Options/help...
How can i get those ? and so, how can i play with Cloth ?
6514.66 In reply to 6514.65
Those extra Buttons are homemade and it needs some code to add them to the interface.
If you want to play with the scripts (cloth) just copy the two files in your commands folder of moi.
Start MoI and hit TAB to get to the commandline and tipe in the filename without extension. For cloth it is _cloth
I'm working on something like an extension that will add extra buttons to the UI without haveing to deal with any codeing.
We will see how that goes.
Show messages:  1-6  7-26  27-46  47-66  67-73
