Styles Selection
All  1-2  3-4
6513.3 In reply to 6513.1
Hi Sharif, if you mean some way to cluster styles together themselves to control as a group, no there isn't any method for that currently but that is something I want to look at adding for v4, like being able to set up some kind of folder hierarchy of styles so that you could control a bunch of them at once and also collapse some from view too.
It is possible to use object names in combination with styles currently though, if you have a set of objects that span different styles and you want to turn them all on or off together if you assign them all the same name that name will show in the "Objects" section of the scene browser and you could go to that item to hide/show them all together.
6513.4
Thanks Michael and BurrMan for the solution
-sharif
Show messages: All  1-2  3-4
