The Alfa-holics
 1-2  3-22  23-30
6512.23 In reply to 6512.22
Cool I will drive a super car! :)
And put on it the fabulous textures of the incredible Vervette online!
http://www.taron.de/Vervette/sandbox/
PS Seems the reflexions of your renderings on the wheel car fender are "inversed" (very "dark" ) ???
Else some fantasy :)
EDITED: 28 Jan 2021 by PILOU
6512.24 In reply to 6512.23
@Pilou
You mean flipped normals? I think it's up to the Dino's lighting setting that darker areas,plus add a tonemapped effect that emphatize the local shadows
It's not a render,it's Moi screenshot.You can notice the seams on the carbody the Moi SubD converter did when imported...100% Moi :)
It's a solid like you see in your image,spending more time it is possible to build the inner parts and make better joints between doors and body and so on..
Final surface has slightly different seams,comparing to those in the image above because I did little adjustments before converting
6512.25 In reply to 6512.24
Ah yes, i have forgotten that the very speedy render of Moi permit to make some screen shots for show works in progress with a sufficient result!
6512.26 In reply to 6512.25
Nice model Mauro, Cuore Sportivo lives forever :-)
Mik
6512.27
Thanks Mik :)
Here two simple photo-rendering without special effects just to close this experiment with SubD
Basic studio
Basic outdoor
Sadly I must stopped to render because of my 15 years old hardware:
Intel Core Duo Quad 2.66 Ghz
Gtx 460
8G Ram
I could do much more but there are limits...I'll buy new hardware this year.
During importing Obj to Blender i founded problems few times:objects far from original position
Import Obj using scale=20 to get right dimensions
To solve this i converted objects in Moi using FBX export setting to last versions
Works fine :) without change scale settings to find right dimensions
Moi 1---FBX export---Blender=1
Alfa-holics thread will go on...too much stuff to tell :)
M
You are an hero to use Blender!
I am not genetical modified for that! :D
6512.29 In reply to 6512.28
6512.30 In reply to 6512.27
Wow it looks great! - Michael
Show messages:  1-2  3-22  23-30
