CustomUI
 1  …  22-41  42-61  62-81  82-101  102-121  …  522
6507.62 In reply to 6507.61
So I did an experiment with creating some sub folders to organize my scripts and commands. It's not exactly what you would think it should be, but it works.
I've basically got "every command and script there is".... (lol)
What I would like is more of a set of categories than one huge list with 200 commands in it.
Since the script isn't reading "folders" and such (it may change later) I just used "added buttons" on the command bar, each pointing to sub folders, where I can organize my scripts into categories.
The only pitfall is you have to leave copies of all the commands and scripts in the original places also, if you want to access them from "MoI" to, and not just Max's plug.
It involves creating copies of the 2 script ui files and making a couple hand edits, then creating your sub folders and putting copies of your group of scripts in there.
If anyone was interested, I'd make a short video to explain it.
6507.63 In reply to 6507.62
I was wondering what this does to MoI's "run commands and scripts differently" mechanism....
I know there needs to be a difference in running inline scripts and commands etc, but was wondering what happens to this when things are run through Max's plugin? Like, are the inline scripts in my scripts folder being run as commands now, when launched with Max's plug? Or, if I put commands, in a subfolder system, which Max's plug can access, are they then run out of commands control and only running as inline scripts?
Thanks for any help you have on this.
6507.64 In reply to 6507.54
Hi Max,
> to this (for example)
var Path =  "D:\\My photo gallery\\3D\\Snapshots\\"
Thanks for that...perfect!
6507.65 In reply to 6507.63
Hi Burr,
It shouldn't really do anything to it... the plugin uses the same controls that MoI's regular UI uses, so it should behave the same as other things.
Which part of the plug-in are you asking about? Which particular module I mean.
I wouldn't think so... But which part of the plug-in runs scripts from your scripts folder?
Normally only things in the commands folder are run as a command.
I guess I'm not really sure of the details here... can you maybe be a little more specific about the exact subfolder that you're talking about (under "commands" ? Or under somewhere else? and what part of the plug-in handles this piece that you're asking about?
6507.66 In reply to 6507.65
I reefing to this part of the plug here:
""""""""""""""ExtScripts
This addon dynamically generates list of all external scripts. Also it adds to the list some "hidden" MoI commands.
There is another version of this addon - ExtScriptsFull. It works exactly as ExtScripts, but It loads all MoI commands.
You can open ExtScripts.menu.htm(ExtScriptsFull.menu.htm) with Notepad and edit "maxlines" value ( default 50 ) to change the maximum number of lines."""""""""""""""""
THis is the one that generates a flyout with commands listed in it. It traverses the MoI commands folder for this.
I keep my inline scripts in the MoI "Scripts" folder, which MoI looks in also, but you had mentioned before that scripts in there will be handled differently.
I altered Max's plug to also grab my inline scripts from MoI's Scripts folder, and also did some experiments with generating some extra sub folders in there too. Max's plug will actually grab them from my "my documents" folder if I direct it to.
So I guess I was just wondering if they run in the context they would normally be run as if MoI was running them with it's default behavior..
6507.67 In reply to 6507.66
Hi Burr,
The only thing to be aware of with other directories is that if the name that is eventually set as the command="" attribute on the does not have a full path on it, like if it's just the plain command name itself, MoI will only find it if it's under the commands or scripts folders. So if you want to put a script somewhere else other than under scripts you can do that but the thing that eventually gets passed to moi.command.execCommand() should be have the full path and file extension on it and not just the plain name.
Yeah, if you haven't modified anything else in that, it looks like it extracts just the plain name and that goes into a command="" attribute on a menu item and so whatever's in there will get passed to moi.command.execCommand() - it will behave the same as if you put that same thing into a keyboard shortcut or typed-in command name. If it finds a matching file of that name inside the commands folder, it will run it as a command. It will also check in the scripts folder, if it finds it there it will load that file and run it as an inline script. If it was passed in a full path it loads it and runs it as inline script. If instead of a file name it starts with "script:" then that text is itself run as inline script instead of being taken as a file name to load, this is all the same as what you get for keyboard shortcuts.
Hope this helps...
Several scripts of my shortcut key options are missing from the Ext. Scripts.
They are Ctrl-C, Ctrl-S, Ctrl-O, Ctrl-N, Ctrl-G, and Ctrl-I.
I have not checked everything yet.
Any idea of why this would be?
So the Ext. Scripts list was made by scanning "commands" folder, which explains why pipe and rotateobjects are not capitalized,
and why the oneliner scripts are not included.
Checked through all of my shortcuts. _FxGraph and _cMorph are not in the Ext. Scripts list.
ArrayCurve is missing.
ArrayGrid is missing.
IncrementalSave is missing.
PastePart is missing.
CopyClipboard is missing.
Intersect is missing.
Cut is missing.
Nudge is present. Does it do anything? (The six Nudge commands are not present, which is OK.)
New, Open, Paste, and Save are missing, but they do not have htm files.
EDITED: 13 Feb 2014 by BEMFARMER
6507.69 In reply to 6507.68
Hey Brian,
It looks like you're listing MoI's default commands...Not custom ones... There is the ext.scripts FULL that will include MoI's commands in the list. But if you don't want "all the commands listed", If you open the extscripts htm file in notepad, at the top a couple lines down there is an entry for "add command", where you can add just a few that you want. This is the separated list at the top...
6507.70 In reply to 6507.69
Thank you Burrman.
Amazing again!
must try it before French translation manual of this new Max opus!
EDITED: 13 Feb 2014 by PILOU
Can you put an image of the arborescence ?
Ok I have some results :)
No problem with the scripts :) but for save objects Snapshots!
For the moment I have all in the Moi Folder!
The + appears, i can enter a name, but objects selected don't go on the Folder Objects! (is this the Library Object ?
I see the 3 objects examples from this folder and can load them but not save new!
must I initialize some path even this is yet existing?
Idem for Snaphot : screen don't go on the Snapshot folder!
And I must install the Dinos Lighting Options for run your Light icon?
PS Same result with the CustomInitUAC !
EDITED: 17 Feb 2014 by PILOU
6507.74 In reply to 6507.73
I avoided storing things in the MoI application directory so I store Snapshots and Objects in My Documents, just make directories where you like and point to them as I did in the .htm files below...
6507.75 In reply to 6507.74
Not better! :(
Maybe because I am on Vista 32 bits ?
I have believed that the error was from "Moi" and not "MoI 3.0 beta Nov-19-2013" that I have on my arborescence
Object Library;MoI\objects original should be
Object Library;MoI 3.0 beta Nov-19-2013\objects
or
Object Library;C:\Program Files\MoI 3.0 beta Nov-19-2013\objects
Edit!
Ok I erase all and reload all and now that works fine! :)
It was that I suspected: Object Library;C:\Program Files\MoI 3.0 beta Nov-19-2013\objects
against
Object Library;MoI\objects !!!
Have you the same bug ? And it's a repetive bug!
After use the Max Smirnov SnapShot the "Area, Zoom, Pan, Reset" are not more visible on some views inside MOI!
I have like Danny (thx) the Folder Snapshot out of the Moi Folder so modify only the line !
var Path = moi.command.getOption('ExePath', false) + "\\snapshots\\";
in
var Path = "C:\\Users\\Pilou\\Desktop\\maxsmirnov\\snapshots\\";
And about The Lighting Options by Dinos? Where is it ? adress post ?
What is the installation with Max plugin?
Does it conflict whith the native Lightings options of the Options menu of Moi ?
6507.78 In reply to 6507.75
>> It was that I suspected: Object Library;C:\Program Files\MoI 3.0 beta Nov-19-2013\objects against Object Library;MoI\objects !!!
Object Library;MoI\objects? Of course it doesn't work :)
You should use a full path or MOI (all capitals) abbrevation.
Tried to reproduce this issue. Yes, "Area, Zoom, Pan, Reset" dissapears after language switching (my script switches language to disable viewport labels).
But seems it's a MoI bug. If you want to reproduce it follow the steps below:
1. Copy EnglishStrings.txt to TestStrings.txt
2. In the Options menu: Switch language to English, Switch to Test, then back to English.
3. It disappears.
http://moi3d.com/forum/index.php?webtag=MOI&msg=5222.48
Just download Dinos's LightingOptions.htm, and put it to ui/ folder (overwrite the original one)
6507.79 In reply to 6507.78
Thx for the infos!
I will try that!
But another little question :)
Say I have several libraries of Objects
I must change the text of the "ObjLibrary.cfg.htm" or i can put several lines inside it or...there is another trick ?
6507.80 In reply to 6507.79
put several lines inside ObjLibrary.cfg.htm
6507.81 In reply to 6507.80
Cool & fabulous for the libraries!!
About the Dinos lighting plugin
I have a PC must i paste also this file ? .DS_Store
French or English i have this result so a path must bad somewhere!
Show messages:  1  2-21  22-41  42-61  62-81  82-101  102-121  122-141  …  522
