CustomUI
 1-13  14-33  34-53  54-73  74-93  94-113  …  514-522
6507.54 In reply to 6507.53
Hi DannyT,
You can change the path manually.
Open "84 Snapshot.htm" with notepad and change this line
var Path =  moi.command.getOption('ExePath', false) + "\\snapshots\\";
to this (for example)
var Path =  "D:\\My photo gallery\\3D\\Snapshots\\";
You have to use double-slashes. And don't forget to put \\ at the end of the path.
6507.55 In reply to 6507.27
> Hi Tommy,
> > I personally enjoy MoI 10 times more now with Max' script installed
> It's cool that it has made things so much better for you!
> Are there some particular plug-ins that you are using very frequently for your work? Which ones are they?
> - Michael
It's kind of part of a bigger topic for me, but here you go:
In one kind of work I do, I let myself be inspired by basic forms or certain functions, create an object out of them and then see if I can make them into interesting images, more like a photographer (using Thea Render) than like an engineer.
So for me all the generator scripts are very useful, interesting and inspiring.
For instance, this image is a Loft between the different Levels of a Hilbert Curve:
http://www.screendream.de/
(BTW. It's also an example of an object that hits the limits of 32 Bit - MoI is hardly able to build and export it. ;-) ).
But there are many other cases. One time I need a sinus curve, another time the spherical points may come in handy or a baseball.
Since I work freelance in a wide range of jobs and topics, I never know what I will need next time, so having all possible options easily accessible multiplies the usefulness of MoI and I will turn to it with more confidence.
At the same time, having all these scripts may also help me creating my own or extending one if need should be.
If the "external scripts" menu in Max' script would have some way of sorting into categories with submenues (in the best case simply from file system folders), it would be basically all I ever need from such a plugins menu.
Several things in MoI are rather hidden in the default GUI, so for instance I hardly ever use the lighting options, but with Max' script they are right at hand so I will remember to actually use them to better visualize certain surfaces.
The object library is something I'm used to from many other applications, Thea Render for instance has a brilliantly integrated library for materials, objects, textures, lights etc. and that makes scene setup much faster, so again, this part of Max' plugin will encourage me to save certain parts I use more often. In theory I could save such objects into some folder and import them, but having them close at hand in this menu makes it much more obvious.
What it all boils down to: I'm used to working with Softimage XSI, Lightwave and other much more complex tools than MoI, so complexity isn't something I have a problem with, as long as it is well presented. What I HAVE problems with is, if existing functions or possibilities are hidden under the hood or missing from the interface.
It's not so much a case of this or that script being especially useful, but the sheer wealth of scripts being usable in a well integrated way makes MoI applicable to more situations.
I believe that by trying too hard to keep MoI simple it actually can go the other way. :-)
I would be happy with an "expert view" I guess.
But that's another discussion entirely... ;-)
YMMV of course.
Cheers,
Tom
6507.56 In reply to 6507.55
Hi Tom, basically the main goal behind MoI is to make it quick and simple to draw basic models, not really to be a big accumulation of a whole bunch of different tools just gathered together swiss army knife fashion...
That's why a "script organizer" just has not been a big priority so far. I do expect to get it to something along those lines in the future though, but there are only so many hours in the day and there are much more basic fundamental tools that I'm focused on first since they have a wider application to MoI's main goal.
Well, I guess you have exactly that with Max's CustomUI extension right here, don't you?
Basically I'm still right now in the process of working more on the fundamental tools in MoI, I just have not yet had the time to focus a lot of effort on extensions and scriptability, although as you can see from Max's work there is a lot you can do with scripting already right now. At some point in the future I should be able to focus a lot more attention on the general area of scripting and make a lot of improvements geared towards that, including stuff for helping both script authors and also consumers of scritps as well. But only once I've got more of the fundamentals covered to a greater degree.
6507.57 In reply to 6507.54
Hi Max,
Thanks for that, I knew where to find it I just didn't know how it should be formatted, all clear now.
6507.58 In reply to 6507.57
Hi Max,
So I created a copy of the 82 ExtScripts file in the customui folder so I can set a second path/menu option for scripts I store in the MoI scripts folder, outside of the commands folder.
Everything works great. I cant find the name for the commandbar item. The original produces a name of "Ext.Scripts". I thought it was from the base64 icon, but I decoded that to change and it was only the gears.
Can you describe where that name is derived, or how to get it to read Ext.Scripts_B or something like that?
6507.59 In reply to 6507.58
Hi BurrMan
:) The name is right after the icon code.
<moi:CommandMenuButton menu="customui/mods/ExtScriptsFull.menu.htm" icon="data:image/png;base64,...icon....">Ext.scripts</moi:CommandMenuButton>
6507.60 In reply to 6507.59
Thanks Max.
Sorry about that. I don't know how I missed it....
6507.61 In reply to 6507.41
Hi Shayno,
"""""""""Can I change the snapshot.htm to save as a jpg rather than a png ?""""""""""""""
Open the "84 Snapshot.htm" from the customui folder, file in notepad and look for this line towards the bottom:
vp.render(w, h).save(Path+time+"-["+vp.name+"].png");
Change the png to jpg and save the file.
6507.62 In reply to 6507.61
So I did an experiment with creating some sub folders to organize my scripts and commands. It's not exactly what you would think it should be, but it works.
I've basically got "every command and script there is".... (lol)
What I would like is more of a set of categories than one huge list with 200 commands in it.
Since the script isn't reading "folders" and such (it may change later) I just used "added buttons" on the command bar, each pointing to sub folders, where I can organize my scripts into categories.
The only pitfall is you have to leave copies of all the commands and scripts in the original places also, if you want to access them from "MoI" to, and not just Max's plug.
It involves creating copies of the 2 script ui files and making a couple hand edits, then creating your sub folders and putting copies of your group of scripts in there.
If anyone was interested, I'd make a short video to explain it.
6507.63 In reply to 6507.62
I was wondering what this does to MoI's "run commands and scripts differently" mechanism....
I know there needs to be a difference in running inline scripts and commands etc, but was wondering what happens to this when things are run through Max's plugin? Like, are the inline scripts in my scripts folder being run as commands now, when launched with Max's plug? Or, if I put commands, in a subfolder system, which Max's plug can access, are they then run out of commands control and only running as inline scripts?
Thanks for any help you have on this.
6507.64 In reply to 6507.54
Hi Max,
Thanks for that...perfect!
6507.65 In reply to 6507.63
Hi Burr,
It shouldn't really do anything to it... the plugin uses the same controls that MoI's regular UI uses, so it should behave the same as other things.
Which part of the plug-in are you asking about? Which particular module I mean.
I wouldn't think so... But which part of the plug-in runs scripts from your scripts folder?
Normally only things in the commands folder are run as a command.
I guess I'm not really sure of the details here... can you maybe be a little more specific about the exact subfolder that you're talking about (under "commands" ? Or under somewhere else? and what part of the plug-in handles this piece that you're asking about?
6507.66 In reply to 6507.65
I reefing to this part of the plug here:
""""""""""""""ExtScripts
This addon dynamically generates list of all external scripts. Also it adds to the list some "hidden" MoI commands.
There is another version of this addon - ExtScriptsFull. It works exactly as ExtScripts, but It loads all MoI commands.
You can open ExtScripts.menu.htm(ExtScriptsFull.menu.htm) with Notepad and edit "maxlines" value ( default 50 ) to change the maximum number of lines."""""""""""""""""
THis is the one that generates a flyout with commands listed in it. It traverses the MoI commands folder for this.
I keep my inline scripts in the MoI "Scripts" folder, which MoI looks in also, but you had mentioned before that scripts in there will be handled differently.
I altered Max's plug to also grab my inline scripts from MoI's Scripts folder, and also did some experiments with generating some extra sub folders in there too. Max's plug will actually grab them from my "my documents" folder if I direct it to.
So I guess I was just wondering if they run in the context they would normally be run as if MoI was running them with it's default behavior..
6507.67 In reply to 6507.66
Hi Burr,
The only thing to be aware of with other directories is that if the name that is eventually set as the command="" attribute on the does not have a full path on it, like if it's just the plain command name itself, MoI will only find it if it's under the commands or scripts folders. So if you want to put a script somewhere else other than under scripts you can do that but the thing that eventually gets passed to moi.command.execCommand() should be have the full path and file extension on it and not just the plain name.
Yeah, if you haven't modified anything else in that, it looks like it extracts just the plain name and that goes into a command="" attribute on a menu item and so whatever's in there will get passed to moi.command.execCommand() - it will behave the same as if you put that same thing into a keyboard shortcut or typed-in command name. If it finds a matching file of that name inside the commands folder, it will run it as a command. It will also check in the scripts folder, if it finds it there it will load that file and run it as an inline script. If it was passed in a full path it loads it and runs it as inline script. If instead of a file name it starts with "script:" then that text is itself run as inline script instead of being taken as a file name to load, this is all the same as what you get for keyboard shortcuts.
Hope this helps...
Several scripts of my shortcut key options are missing from the Ext. Scripts.
They are Ctrl-C, Ctrl-S, Ctrl-O, Ctrl-N, Ctrl-G, and Ctrl-I.
I have not checked everything yet.
Any idea of why this would be?
So the Ext. Scripts list was made by scanning "commands" folder, which explains why pipe and rotateobjects are not capitalized,
and why the oneliner scripts are not included.
Checked through all of my shortcuts. _FxGraph and _cMorph are not in the Ext. Scripts list.
ArrayCurve is missing.
ArrayGrid is missing.
IncrementalSave is missing.
PastePart is missing.
CopyClipboard is missing.
Intersect is missing.
Cut is missing.
Nudge is present. Does it do anything? (The six Nudge commands are not present, which is OK.)
New, Open, Paste, and Save are missing, but they do not have htm files.
EDITED: 13 Feb 2014 by BEMFARMER
6507.69 In reply to 6507.68
Hey Brian,
It looks like you're listing MoI's default commands...Not custom ones... There is the ext.scripts FULL that will include MoI's commands in the list. But if you don't want "all the commands listed", If you open the extscripts htm file in notepad, at the top a couple lines down there is an entry for "add command", where you can add just a few that you want. This is the separated list at the top...
6507.70 In reply to 6507.69
Thank you Burrman.
Amazing again!
must try it before French translation manual of this new Max opus!
EDITED: 13 Feb 2014 by PILOU
Can you put an image of the arborescence ?
Ok I have some results :)
No problem with the scripts :) but for save objects Snapshots!
For the moment I have all in the Moi Folder!
The + appears, i can enter a name, but objects selected don't go on the Folder Objects! (is this the Library Object ?
I see the 3 objects examples from this folder and can load them but not save new!
must I initialize some path even this is yet existing?
Idem for Snaphot : screen don't go on the Snapshot folder!
And I must install the Dinos Lighting Options for run your Light icon?
PS Same result with the CustomInitUAC !
EDITED: 17 Feb 2014 by PILOU
Show messages:  1-13  14-33  34-53  54-73  74-93  94-113  114-133  …  514-522
