CustomUI
1-17
478-497
498-517
518-522
WN
22 Mar 2023 (518 of 522)
6507.518
In reply to
6507.517
Hi Colin.
If I remember correctly, this plugin is installed separately, then you need to delete its files.
I also have the file " 88 SubdivTools.js" but renaming it doesn't work, only deleting or moving it.
I don't see it in your screenshot.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
22 Mar 2023 (519 of 522)
6507.519
In reply to
6507.517
Hi Colin,
> All of which makes me assume it must be part of the original V3 Command Bar install..?
No, those sub-d buttons are not part of the regular V3 UI.
But they may pre-date CustomUI and may have had instructions to insert them by modifying CommandBar.htm .
If you can post your CommandBar.htm I will see if that's where they are.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Colin
23 Mar 2023 (520 of 522)
6507.520
In reply to
6507.519
Thanks for clarifying that.
Here's that CommandBar.htm you're wanting.
HTH, Colin
CommandBar.htm
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
23 Mar 2023 (521 of 522)
6507.521
In reply to
6507.520
Hi Colin, yeah they were added in to there.
I've edited them out so if you replace your current CommandBar.htm with this attached version that should get rid of them.
CommandBar.htm
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Colin
23 Mar 2023 (522 of 522)
6507.522
In reply to
6507.521
Thanks greatly for that, it's much appreciated.
Just tested & works a treat.
regards Colin
EDITED: 23 Mar 2023 by COLIN
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
458-477
478-497
498-517
518-522
