CustomUI
 1-20  …  301-320  321-340  341-360  361-380  381-400  …  521-522
6507.341 In reply to 6507.340
This means that you must maybe save your original folder ui/CommandBar in your favorite save place in case of problem with your future UI! ;)
6507.342 In reply to 6507.340
Hi Takeda, yes part of the installation of the CustomUI extension is that it overwrites one of MoI's files, it's a file named CommandBar.htm that is in the \ui sub-folder inside of MoI's main installation.
So the backup step means to save your original CommandBar.htm file somewhere else so if you have any problem you can restore the original back again without needing to do a full re-install.
Message 6507.343 deleted 28 Dec 2018 by THARSO
6507.344
Hi, Where can I find light options addon? I found one that didnt work with this plugin. Thx
6507.345 In reply to 6507.344
Hi Tharso,
Which version of CustomUI are you using - the one for MoI v3 or the one for MoI v4?
6507.346
Just tried to apply CustomUI to new beta, but it doesn't worl correctly - scripts, object and lighting options folders are empty. Anyone has CustomUI setup which works for last beta?
6507.347 In reply to 6507.346
Hi glmr,
The latest version of customUI works very well when installed properly in MoI4 beta.
Are you Mac or Windows?
6507.348 In reply to 6507.347
I am on Windows. MoI 4.0 beta Oct-17-2018
UPD: I'm an idiot who doesn't read instructions. Now it works.
EDITED: 13 Jan 2019 by GLMR
6507.349 In reply to 6507.348
UPD2: can't find snapshot button even with correct installation
6507.350 In reply to 6507.349
My camera icon is also missing in MoI4beta. It is present in MoI3.
6507.351 In reply to 6507.349
Hi glmr,
re: UPD2: can't find snapshot button even with correct installation
Is there a file Snapshot.js located in your MoI appdata\startup folder?
6507.352 In reply to 6507.351
My 82 Snapshot.js file was missing from MoiAppData\startup.
Downloaded max's v2 of customui from his website, to downloads folder, extracted, and copied
82 Snapshot to the MoiAppData\startup directory, and the camera (snapshot) is back.
A few other .js files are still missing, maybe messed up with MiniSidepane.js alterations???
6507.353 In reply to 6507.352
Hi Brian, I wouldn't think that MiniSidepane.js alterations would be able to make files go missing... Is it possible you had an older version of it? The latest one from Max's file archive here: http://moi.maxsm.net/media/files/ (look for CustomUI.2.0.beta2.zip) has it, maybe it was missing from previous versions.
6507.354 In reply to 6507.353
Hi Michael, You are likely right. My initial install was for the first beta. It is nice to have link to current version. I keep links to such useful sites in Chrome bookmark bar. (I use snaggit13 quite a bit for window captures, rather than snapshot.)
6507.355
Hi All,
I would like to install customUI to MoI 4 latest beta and have it portable but what I read so far I would have to extract the custom UI to appdata of user instead of MoI directory.
Is there any way to customize a MoI4 and have it portable?
Super benefit would be if I won't have to go through same complicated process of customization over again if newer version of MoI is released.
Thanks a lot.
6507.356 In reply to 6507.355
Hi Mr. Yuri, if you create a folder named "appdata" inside of the MoI portable folder as a sibling to "commands", "ui", etc... then MoI will use that folder as its appdata location instead of the regular spot. So you can use that to make a portable set up of anything that is designed to be in appdata.
I'd recommend setting up whatever you can inside the appdata folder and then you would just need to copy that folder over into the new version.
6507.357 In reply to 6507.356
What is the moi portable folder?
Just now trying to convert v3 to v4 Beta and now realize that customizations can be separated in the appdir folder instead of install folder but not sure if I need to make a folder in appdir and install ui, script, commands etc there instead?
Thanks!
Jason
6507.358 In reply to 6507.357
Are people setting up portable MoI on a USB Flash Drive?
6507.359 In reply to 6507.357
Max made an update to the custom UI that moved its i stall to the appdata folder, to stay vompatable with MoI's move to that folder... that is where all things are installed now, excepting MoI's root install dir stuff...
To get your "portable" MoI, you need to have all that appdata dir in your MoI root install location. Wotks just fine.
@bemfarmer
People do!!!! All my MoI installs have been setup this way. It's all on a usb stick. With me wherever i go!
6507.360 In reply to 6507.357
Hi Brummett,
It's the folder where you have copied the MoI installation. It's for the case where you're using MoI as a "portable" program meaning that it is copied on to a USB drive and can be run directly from the USB drive on another computer.
MoI v4 will automatically create folders in appdata for commands and startup scripts. You can put your custom commands in there instead of inside the install folder, that way new installs will see them automatically and you won't have to copy those into a new install.
If you have made a scripts folder in your install you can also create a scripts sub-folder in the Moi appdata folder and put them there.
UI modifications would still need to be applied to the install, but if the UI modification is done by script code rather than static file changes, in v4 you can put the script file in the appdata startup folder so it will be run when MoI launches. Max's CustomUI extension for v4 has been redone to work this way for example.
Show messages:  1-20  …  281-300  301-320  321-340  341-360  361-380  381-400  401-420  …  521-522
