CustomUI
 1-20  …  141-160  161-180  181-200  201-220  221-240  …  521-522
6507.181 In reply to 6507.180
Wow, that was fast. Works fine, woo hoo!
6507.182
Camera switcher for CustomUI :)
put .htm file in /ui/customui/ folder
right click - save camera position
left click - load camera position
EDITED: 7 Mar 2022 by SMIRNOV
6507.183 In reply to 6507.182
Thanks Max thats neat
Is there any way that it can save the set positions on moi close , as it forgets what you set
cheers
shayne
6507.184 In reply to 6507.182
Is there additional instructions to get this to work? I could find no customui folder in the MoI ui directory, so i created one and put the htm file there but it does not show when I run MoI. What am I missing?
_________________________
Don Cheke
Visit: Textual Creations
6507.185 In reply to 6507.184
Hi Don, if I remember right I think you need to unzip the file into MoI's main installation folder.
That will then replace one of Moi's .htm files inside the \ui folder to show the additional UI, and that will also then create the CustomUI folder for you during that unzipping process since it's stored in the .zip file.
6507.186 In reply to 6507.184
Post 1 has instructions. It can be easy, but for me it was hard to do it the first time, back with Moi3Betas.
Recently, I placed the CustomUI...zip file in the x86/Moi3 directory and unzipped it there. Easy :-)
6507.187 In reply to 6507.186
Thanks Michael and Brian. I got it to install and work.
Don Cheke
6507.188 In reply to 6507.187
The only thing you should watch out for with this type of "install", is Michael may make changes to something like "CommandBar.htm" and you are overwriting with something outdated...
You "Should" understand what is added in something like CommandBar.htm and just make that edit by hand, so you don't break your future installs.......
2 cents....
6507.189 In reply to 6507.188
Thanks, I probably won't use it anyway. I really just wanted to see what the camera switch did.
Don Cheke
6507.190 In reply to 6507.1
Hello all,
It's been a while since I've visited the forum,
so I'm sorry if this has been covered before.
I couldn't find anything on it.
How does the snapshot option of the CustomUI work?
When I click on it, the screen blinks but doesn't put an image in the snapshot folder.
I have the snapshot folder located in MoI's main folder. Not sure what I am doing wrong.
I have a few other questions, but I thought I'd start out with this one 1st. :-)
Jesse
6507.191 In reply to 6507.190
what os?
6507.192 In reply to 6507.190
Hi Jesse, in recent versions of Windows, the operating system tries to prohibit programs from changing anything under c:\Program Files other than when it was installed, as a way to keep things from being messed with by viruses and things like that.
Since the CustomUI Snapshots directory is in there, that means that by default it won't be writable.
But if you give a program elevated privileges it will then allow it to write stuff there.
One way to give a program elevated privileges is to right-click it and choose "Run as administrator". If you do that, does the snapshot function start to work ok for you during that run? If so then you can set it to always run as administrator by right-clicking the shortcut, go to Properties, Compatibility tab and there's a checkbox at the bottom "Run this program as an administrator", if you set that the shortcut will always launch it with elevated privileges.
It would probably be better to have the snapshots folder located somewhere that was writable by default, like under %AppData%\Moi\snapshots, that way it would work without needing the program to have elevated privileges.
6507.193 In reply to 6507.190
Hi Jesse,
I agree with Michael with keeping your data out of the Programs directory and putting it somewhere else you can do that following these instructions earlier on this thread http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.53
Did the same thing with the objects.
6507.194 In reply to 6507.1
Hi, is customUI now valid for moi3D ?
thakx
6507.195 In reply to 6507.194
Yes. CustomUI works great with MoI 3.0
6507.196 In reply to 6507.195
Hi Max, I just installed the CustomUI on my Mac and really like it. Great work! Thank you.
Please can you advice regarding the lightning button, it currenly says no Options Add on found. Where can I find that add on and where would I need to copy it?
Thank you
Tarek
EDITED: 8 Nov 2014 by TAREK
6507.197 In reply to 6507.196
HI TAREK
I just had to figure this out again recently, when installing on my laptop.
Max and PILOU answered this question many posts back.
Dino's lightingoptions htm file needs to be copied to the Moi ui folder.
It is located at post 48 here: http://moi3d.com/forum/index.php?webtag=MOI&msg=5222.48
Part of the answer is post 82, here: http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.82
(Open Moi and visit Options/View/LightingOption. Just visit, no need to do anything.)
EDITED: 8 Nov 2014 by BEMFARMER
6507.198 In reply to 6507.197
Thank you Brian,
All worked well after I followed the posts. Much appreciated.
Tarek
6507.199
i am new to moi. i installed the custom ui and it looks great, but i do not see gear or bearing under my objects tab. have i done something wrong? any help is appreciated. thanks
joe
oh...i forgot to mention i am still working off the trial version with intent to purchase. sort of trying to decide between moi and cubify
6507.200 In reply to 6507.199
Deleted due to incorrect statements :-)
EDITED: 17 Mar 2017 by BEMFARMER
Show messages:  1-20  …  121-140  141-160  161-180  181-200  201-220  221-240  241-260  …  521-522
