new Moi user: have an object with network made from 4 horizontal curves , one ellipse on top and one ellipse on bottom (see pic1).
pick bottom and make planar. Boolean union network and planar bottom to make one object.
the problem I am having is filleting the bottom. what is best way to pick and use this.
fillet says you can pick the bottom face to fillet. tried that and it does not work.
pick the bottom ellipse and that does not work.
hide the bottom ellipse and pick the bottom edge. the pick picks only a segment of the bottom (there are many segment all around). do not understand that (see pic2) ?
pick the whole object to fillet the bottom that does not work?
I one time did make fillet work , but can not repeat the procedure, forgot how I made it work.
I have used geomagic (alibre) , using moi is new to me and do not understand how fillet work in this semi-complex shape.
I can repeatedly make a circle , extrude , and planar on bottom , union , and fillet , but can not do it using the semi-complex network and planar.
I tried doing a complex bottle tutorial before this and was having problem there with fillet.
attached : pic1 pic2 and model file
