Hi Andrei, you should be able to put anything you put inside a shortcut key inside of a button, insert it into the command=" " part of the button.
The only thing to be aware of is if the script itself has any quote " characters in it, switch any of those to single quote ' characters instead so that they won't be taken as the end of the command=" " attribute itself.
