LOFT method in action
6501.1
Working now on new Hellicopter model, whanted to share with you progress.
This is the MOI "Sculpting" ))) LOFT method in action!
It will be this:
My Portfolio: www.samardac.tumblr.com
A lot of my Tutorials!
Subscribe to my youtube channel: http://www.youtube.com/samardac
Russian community of MOI 3D: www.vk.com/moi3d
6501.2 In reply to 6501.1
Looks great, Andrei. It will be fun to view your updates!
I have a question: other than experience, is there a method/procedure to choosing your profile curves to loft? How much modifications do you make to your basic shapes? This seems to be almost a "point cloud" type operation at this stage, yes?
Ron
6501.3 In reply to 6501.2
Thanx Ron,
I use this script to set one style to all curves that I use to loft one object, it sets unique style without any menus.
script: /* Asign style*/ moi.ui.propertiesPanel.editStyleIndex( moi.geometryDatabase.addStyle().index );
I use this script to select all curves with the same style and loft:
script: /* Expand selection over same styles and loft */ var objects = moi.geometryDatabase.getObjects().getCurves(), points = moi.geometryDatabase.getObjects().getPoints(), styles = new Array(); for (var i = 0; i < points.length; i++) { objects.addObject(points.item(i))} for ( var i = 0; i < objects.length; ++i ) { var obj = objects.item(i); if ( obj.selected ) styles[obj.styleIndex] = true; } for ( var i = 0; i < objects.length; ++i ) { var obj = objects.item(i); if ( styles[obj.styleIndex] ) obj.selected = true; }; moi.command.execCommand( 'loft' );
Also I have custom show/hide system that was made from diffrent scripts and based on objects styles. That system allows me to work very fast with this method.
But it is subject of my next tutorial, it is will be a lot of text to describe it here.
There is no any "point cloud" as you can see :)
I made Basic Course of organic shapes in MOI (Loft (Loose, Exact)):
Part 1
Part 2
Part 3
Part 4
Also a lot of tutorials about this method is here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6058.1
