UNDO function
65.1
I hope I haven't missed something but I would expect to find an undo function in the EDIT toolbox. Either undo once or undo by stepping back multiple times. That sounds confussing <BG> Example you want to udo your last 3three steps you could use say "control u" each time you used it you would undo the previous action. Or as some cad programs do you can limit it to just the last action.
If you have something like this I would like to find it.
Very interesting program I am enjoying playing with it.
Jack
65.2 In reply to 65.1
Hi Jack, undo is located on the bottom toolbar, right next to "Save". I've tried to put some of the most frequently used buttons in this area so that they are always visible and available. Stuff on the right-side palettes may not be immediately visible if you have activated some other palette in the same row.
You can also use the keyboard shortcut Control + Z to do an undo as well.
I have thought a little bit about possibly moving the undo, redo, and delete buttons into the Edit toolbox where you expected them. But that would start to make Edit kind of a bit large and overbearing...
