Divide (length) Script?!
All  1-2  3
6493.3 In reply to 6493.1
Hi Lordfox, here is the forum post that shows how to do it:
http://moi3d.com/forum/index.php?webtag=MOI&msg=986.2
The method is to create a point object at the end of the curve, and then use Transform > Array > Curve to replicate that point along the curve at your desired cutting points. Then you can use the Edit > Trim command to cut the curve and use those points as the cutting objects.
Show messages: All  1-2  3
