Divide (length) Script?!
6493.1
Hallo dear readers,
I have a question, is there allready a script for dividing a curve/line segment? Similar like in Illustrator - I mean the DIVIDE (LENGTH) script?
6493.2 In reply to 6493.1
There is a trick using array of a point on the end.
There is a forum topic somewhere...
6493.3 In reply to 6493.1
Hi Lordfox, here is the forum post that shows how to do it:
http://moi3d.com/forum/index.php?webtag=MOI&msg=986.2
The method is to create a point object at the end of the curve, and then use Transform > Array > Curve to replicate that point along the curve at your desired cutting points. Then you can use the Edit > Trim command to cut the curve and use those points as the cutting objects.
