Looooong time to load files
All  1-8  9-12
6492.9
Good to knowk about the issues from iges.
Realy i don't know why the hell i used iges to save the file.
Maby i have to wait very very very very Long time to load the file and than save it as 3dm
thanks alot at all.
6492.10 In reply to 6492.9
Hi Janne, it's probably worth it to try turning off the automatic join on import (uncheck Options > Import/Export > IGES options > "Join surfaces on import") and see if that helps you get the file in more quickly.
Also depending on how the file is structured it may be necessary to turn it off anyway, if for example you have a lot of separate objects that were touching each other originally those may get joined together in bad ways with some unwanted pieces of neighboring parts getting joined together. If that's the case you will need to turn off automatic joining and do a more guided manual joining process of selecting targeted pieces and using Edit > Join after doing the import.
6492.11 In reply to 6492.10
This conversation brings up a question for me.
Michael, what if you happen to receive IGES and you have no control over what that receivable is going to be and someone just man-crushes the IGES.
Are there things that you can do in MoI to get the file to work better, aside from the solutions offered such as mesh and disable auto-join?
Would an export into some other file format out of MoI and then back into MoI help to make an IGES more workable? Or performing various joins after the model is imported and then saving it out as 3dm?
Not that I see IGES much anymore, but in the day that was a common occurrence for me. Perhaps if there is a fix for files like that it could also be macro'd (if import, some commands, export some other format, import again, save final as MoI).
I am only assuming that not much can be done as you got what you got, but I am curious (and a little prayerful) that there is a solution that speeds things up.
Or if someone even knows of a import / export program that can help.
Thoughts?
6492.12 In reply to 6492.11
If you just save the file out to 3DM format, that should then solve the "slow loading" part of the problem, but you still may have other problems to work on after that, like needing to select just specific groups of surfaces and then using Join rather than letting the whole file be processed for joining all together.
Basically you should only use IGES format just for the initial first load of the data into MoI, once you want to continue working on the file don't save it back to IGES format after that, use 3DM format for your in progress stuff.
Show messages: All  1-8  9-12
