Flow question
All  1-8  9-10
When I set the mesh angle to 1 (very low), before creating anything. (before extruding circle to a cylinder), I seemed to have better results. (?)
Used the base surface the same triangle as the solid. (Difference in length of the projection is irrelevant.)
Maybe this is a display artifact? I see that the 3dm I posted is back to mesh angle of 10, but setting it to one looks different (better).
EDITED: 19 Feb 2014 by BEMFARMER
6487.10
Thanks Michael and Bemfarmer. Michael no need to examine UV in project, I found the solution I tested it in diffrent shaeps looks like it works fine. Solution was as I said, you have to flatten trimed surface and use it as base shape. Works very nice!
Show messages: All  1-8  9-10
