Flow question
All  1-5  6-10
6487.6
Looks like I found the way, to make object and target surface make the same size, you need to flatten trimed surface and then use it as base surface :)
Portfolio: www.samardac.tumblr.com
6487.7 In reply to 6487.1
Hi Andrei, can you please post the 3DM model file with your objects in it? I would really need to look at that to give you any answers on what might be wrong, I can't tell things like the UV structure of your base plane by just looking at your screenshots.
You may be running into the same issue described here though:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6453.2
6487.8 In reply to 6487.6
Hi Andrei, yes usually you will want the base surface to be a plane. It's possible to not have a plane for it but that will then change how the transform happens - points that are being transformed are dropped down to the closest point on the base surface, and if your base surface is curved rather than planar it will have some influence on the transformation.
When I set the mesh angle to 1 (very low), before creating anything. (before extruding circle to a cylinder), I seemed to have better results. (?)
Used the base surface the same triangle as the solid. (Difference in length of the projection is irrelevant.)
Maybe this is a display artifact? I see that the 3dm I posted is back to mesh angle of 10, but setting it to one looks different (better).
EDITED: 19 Feb 2014 by BEMFARMER
6487.10
Thanks Michael and Bemfarmer. Michael no need to examine UV in project, I found the solution I tested it in diffrent shaeps looks like it works fine. Solution was as I said, you have to flatten trimed surface and use it as base shape. Works very nice!
Show messages: All  1-5  6-10
