Measuring
All  1-2  3-5
6480.3 In reply to 6480.2
STL is like Polygon format or similar?
As there is a conversion Nurbs to polygons is there a difference between a volume in Nurbs and the result after conversion?
Can we estimate the difference in general ? +- 0.001 Unity
6480.4 In reply to 6480.3
Yup, it's a polygon format.
Yes there will be some small amount of error because of the polygon conversion. It should be pretty small though.
It's hard to estimate it directly, it depends on various model-specific factors like how curvy the surfaces are. If you need particularly high accuracy you may want to use another CAD program to do the measurement rather than using the STL method, unless of course you were actually planning on using some STL based method for generating the physical part in the first place.
6480.5 In reply to 6480.4
Something like freecad http://www.freecadweb.org/ sems has some volume dimensions
even curiously they have not 3dm format ! 3dm is not OpenNurbs?
STEP, IGES, OBJ, STL, DXF, SVG, STL, DAE, IFC or OFF, NASTRAN, VRML in addition to FreeCAD's native Fcstd file format.
EDITED: 30 Jan 2014 by PILOU
Show messages: All  1-2  3-5
