Fillet trouble on converging edges
All  1-8  9-19
6479.9
I have added a blend option for this problem that's not to complicated.
First split the edges you need to fillet at the point you wish the fillet
to start to taper.
Draw a circle the radius you require and sweep the edge you want
the fillet to be constant. Now sweep the edge to taper and add the
option for pointy end.
Trim using the sweeps and then blend faces of the constant edges.
The pointed end is then trimmed back to this position and the profile
of the blends and connecting flat face are used to sweep into the
corner.
Barry-H
EDITED: 30 Jan 2021 by BARRY-H
6479.10 In reply to 6479.9
Thanks Barry. Always nice to have more than one approach to solving these sorts of things. I was able to create much of what you have in your example. For some reason though, I'm getting some pinched edges at the tip of that triangular patched area. Tried this a couple times and got this result each time. It looks like you've got better edges in your example.
6479.11
I joined the blend edges and the straight and swept it with the 2 rails
with the maintain height unchecked (see photo)
It also works as a network.
Barry-H
Size: 40.2 KB, Downloaded: 17 times, Dimensions: 287x230px
6479.12
Hello,
You might want to try no having the fillets converge at a point, rather carve out your desired curves and create a network patch at the pointy end of the fillets, allowing the patch to end it.
6479.13
Brandroid, 30 seconds to solve your problem! Blend G2 - 0.5
My Portfolio: www.samardac.tumblr.com
A lot of my Tutorials!
Russian community of MOI 3D: www.vk.com/moi3d
EDITED: 4 Feb 2014 by ANDREI SAMARDAC
6479.14 In reply to 6479.13
Andrei, thanks for the video. I think I tried this approach earlier on, but I wasn't getting good results. The difference was that I was trimming away a larger portion of the surface before blending. The trim I made was a segment all the way through the back of this solid. When I blended, I got some lumpiness on the back where the flat plane blended with the top. Your trim yielded a better blend, although I wasn't able to join the resulting surfaces into a solid. I made an adjusted trim line and blended that, and I was finally able to get a solid in about 30 seconds of work. This piece has been a headache, but I've learned a lot!
6479.15 In reply to 6479.14
Brandroid I did not understand you, you could not join model using my method? I joined it in video and made solid everythink was ok)
6479.16 In reply to 6479.15
ANdrei,
In your video, you did not trim the top surface "all the way back"... You started at the back seam edge.
When he trimmed it all the way back, he was having issues.
The 2 surfaces at the back (converging area) are not really tangent, or equal, so the blend back there is producing the poor results.
He fixed it by trimming out a larger portion of the top, AND bottom. That is kindof "hiding" the stressed surface.
The best thing would be to re-create that object, and have the back "converged" area come from "one initial piece". Either the bottom piece, or the top piece. One or the other.
6479.17 In reply to 6479.16
BurrMan is right, although initially I replicated everything Andrei did in his video. My first trim line was the same as his, and still I could not get a solid after blending the resulting surfaces; only a joined surface.
Then I cut through entire piece above and below the lip and got an acceptable result.
6479.18
Hello,
The back edges of the original model are not fitting too well, rebuilding the base model from scratch leaves a better end result.
6479.19
Good, understood.
I made new tutorial about Collapsing fillet (disappearing fillet). You can check it here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6058.30
Show messages: All  1-8  9-19
