some challenge!!
 1-13  14-23
6474.14 In reply to 6474.13
Bravo DannyT, very cool! thanks!
Portfolio: www.samardac.tumblr.com
6474.15 In reply to 6474.14
But one thing! How to control angle of this?
6474.16 In reply to 6474.15
Just found, some how it can be controled via chamfer. May be there is onother way to control it?
EDITED: 29 Jan 2014 by ANDREI SAMARDAC
6474.17 In reply to 6474.16
Maybe with this ?
6474.18 In reply to 6474.15
Hi Andrei,
One possibility is if you shoot a 3 point plane coming straight off that chamfer segment edge, you can then select it and use Transform > Rotate > Rotate axis to pivot it by your specific desired angle.
The "rotate axis" transform allows you to pick any line as the rotation axis and your object will pivot about that line.
Just make the plane long enough so that it sticks all the way up through the object after it has been rotated.
6474.19 In reply to 6474.18
Thank you Michael good solution!
6474.20 In reply to 6474.19
Pilou Im not sure I understood your method.
6474.21 In reply to 6474.20
It's just for regulate the 2 extremities of the object to boolean Diff from the big one!
Cut Path with 2 extremities choosen and sweep!
But caps are perpendicular to the path!
I suppose you know the Transform Orient / Orient for Slide an object perpendiculary (or not) to a path! :)
EDITED: 30 Jan 2014 by PILOU
6474.23
People, check out my new tutor about this subject: http://moi3d.com/forum/index.php?webtag=MOI&msg=6058.17
Show messages:  1-13  14-23
