Back with more questions...
All  1-3  4-10
6471.4 In reply to 6471.3
Thanks for the advice on this. I was thinking of combining Blender with MoI, e.g. build a car body using polygons (or NURBS!) and do all of the mechanically bits using NURBS, i.e. wheels, suspension etc etc. I think that would be a good combination, because I don't want to simply abandon Blender after using it for 3 years. As you say though I'll have to practice, practice, practice in MoI before making anything significant!
6471.5
Hi Mike,
I cracked the wallet open last night and bought myself a licence to the program. :) I've not had much of a chance to experiment with different shapes, but I was wondering if it's possible to create a zebra pattern for analysing continunity between surfaces?
6471.6 In reply to 6471.5
Hi GrandeP, thanks very much for your order!
MoI does not currently have a zebra pattern function, but you can get much of the same effect by turning on reflective style lighting. To do that set the check box for "Metallic lighting" which you can find under Options > View > Lighting options.
6471.7 In reply to 6471.6
Thanks Michael, that metallic lighting looks very handy. I watched a tutorial on how to make a wheel, that was in Rhino however, and now I have absolutely no idea what to make first... *this always happens* :(
6471.8 In reply to 6471.7
Hi GrandeP,
Do you have a link to the tutorial?
The first step would likely be drawing a profile curve and then using Revolve to create the starting base shape.
6471.9 In reply to 6471.8
The wheel modeling tutorial can be found here http://www.youtube.com/watch?v=bezdc2XjEV4
There's also this but it's in Alias http://www.youtube.com/watch?v=L0Dm4Jv3Nx0
6471.10 In reply to 6471.9
Hi GrandeP,
I took a quick look at the start, and the first operation in the tutorial looks like a revolve of some curves that he has drawn previously.
So your beginning step to follow along would be to draw in curves similar to what he shows there, then do a revolve on them.
To do that, switch to one of the 2D views, like the Top view, and in MoI launch the curve drawing tool under Draw curve > Freeform, and draw 2 curves something like this:
Select those curves, and then run Construct > Revolve - when you run a command it's a good idea to look in the upper-right corner of the window where it has the prompt that tells you what MoI is expecting for you to do next. In this case you'll be picking the revolve axis, pick the 2 points for the revolve axis on the left side of the curves like this:
That will then generate the disc type shape like this:
That looks like how you'd get started in MoI following along that particular tutorial...
That particular tutorial says in the start that it skips some steps about constructing the curves, so you need to know how to draw curves first before you'd be able to do that one. I'd recommend first going over these introductory tutorials here instead:
http://moi3d.com/2.0/docs/tutorials.htm
Those ones go over things in much more detail and don't skip any steps, they should give you a better introduction on the general process of how to construct things.
Show messages: All  1-3  4-10
