Help creating patch
All  1-5  6-9
6462.6 In reply to 6462.5
The tail section as a separate entity is something I was thinking of too, I've not really used the blend function so will be an interesting exercise for me.
Many thanks for your time.
Alexander
6462.7 In reply to 6462.6
Hi Alex, the "bowl cutting surface" method would go something like this - you'd need to make one large surface that submerges down into the other ones something like this (in this case here I've done a rail revolve using half an ellipse as the rail):
Then with those pieces pushing through each other you can use Edit > Trim to slice them all up and remove excess area to end up with this:
In this method you have to concentrate more effort on making the cutting surface to have the kind of shape you want (the one I did here is not quite right), but it does leave a continuous result since the whole filled in area comes from one single surface.
6462.8 In reply to 6462.7
Ahh yes, great idea. Looks clean and tidy. Will give it a try, thanks again Michael
Alexander
I forget at each time this method! :)
Show messages: All  1-5  6-9
