scripts
All  1-3  4-7
6460.4 In reply to 6460.3
Hi Ron,
> If you don't mind, what would you say are the most "gotta have" scripts to add to MoI?
I'd say it's that select naked edges one you already put in, and then the only one that I use very regularly is one for inverting the selection:
script: /*Invert selection*/ moi.geometryDatabase.invertSelection();
6460.5 In reply to 6460.3
Hi Ron,
I can see you're doing some product design I always use these;
Measure distance: http://kyticka.webzdarma.cz/3d/moi/#MeasureDistance
Measure angle: http://moi3d.com/forum/index.php?webtag=MOI&msg=5390.3
6460.6 In reply to 6460.4
hi ron!
..all time favourite has to be..
MaximizeViewport – switches viewport under the current mouse cursor location between respective split and top(bottom)/front(back)/right(left)/3D view.
quote:
script:if ( moi.ui.mainWindow.viewpanel.mode != 'split' ) { moi.ui.mainWindow.viewpanel.mode = 'split' } else { var viewport = moi.ui.getViewportUnderMouse(); if ( viewport ) viewport.viewpanel.mode = viewport.name; }
..followed by those 3 toggles
ToggleGridSnap:
quote:
script:moi.drawingAids.gridSnap = !moi.drawingAids.gridSnap;
ToogleStraightSnap:
quote:
script:moi.drawingAids.straightSnap = !moi.drawingAids.straightSnap;
ToogleObjectSnap:
quote:
script:moi.drawingAids.objectSnap = !moi.drawingAids.objectSnap;
more workflow specific for going in/out 2D applications:
quote:
script: /*! Copy AI format to clipboard */ moi.geometryDatabase.copyToClipboardAI();
quote:
script: /*! Copy PDF format to clipboard */ moi.geometryDatabase.copyToClipboardPDF();
marco
6460.7
Thanks everyone! They all look like very useful suggestions.
Ron
Show messages: All  1-3  4-7
