Extrude very slow in v3 beta
All  1-4  5-8
6455.5 In reply to 6455.4
Hi jik, those are some great railroad models!
> I also played with parameters at .stl export, and found better to use more polygons and
> let the printing software to "antialias" the surfaces.
Yeah also using the "Divide larger than" parameter can be good for getting more evenly sized pieces. If you put in a distance in "Divide larger than", any polygon that's bigger than that size will get diced up further. It can help to avoid making triangles that span a large distance across the model. Something like around 1/20 of the overall size of the model can be good to put in for "Divide larger than".
6455.6 In reply to 6455.4
quote:
My experience is, using a lot of NURBS surfaces slows down the rendering and manipulating
did you increase your viewport mesh angle(initial would be 10)? you could also uncheck "Add details to inflections" and "Display hidden lines", which should definitely improve the overall handling.
6455.7 In reply to 6455.6
Very nice! What are you using to print those?
6455.8 In reply to 6455.7
Supagoat:
originally i have tried photopolymer, but the models are too light (0,5g)
now I use print to wax and lost-wax technology casting using brass.
photopolymer
wax prints
brass casts (the silver ones are from pakfong, just for testing)
coi:
to be honest, i didn't play with those settings, but will try, thanks for tip
Jozef
Show messages: All  1-4  5-8
