sweep problem
All  1-7  8
6442.8 In reply to 6442.7
Hi wim,
> but most of all, when exporting to Maxwellrender (.obj format)
> then everything blows up by 100 if I set it to cm. and I go back
> and forth a few times between moi and mw, so switching the
> units is a pain.
You can solve this one by setting the option in MoI under Options > Import/Export > OBJ options > "Scale factor". If you put in 0.01 for that scale factor option, your exported OBJ file will get scaled down by 1/100 in size just at export time, that should get it at the size that Maxwell likes to have things.
> If there was an easier method to communicate with
> mw, it would be great.
This is really the best way, because if you post here there is a chance that someone else may be able to help if I'm away on some family emergency like I am now.
Thanks, - Michael
Show messages: All  1-7  8
