sweep problem
All  1-6  7-8
6442.7 In reply to 6442.6
Thanks Michael. I have set the measurements to meters for a few reasons: the caddy (the final object) is 2 meters long, but most of all, when exporting to Maxwellrender (.obj format) then everything blows up by 100 if I set it to cm. and I go back and forth a few times between moi and mw, so switching the units is a pain. the object I had trouble with is 1 mm thick, but of course with the rounding it is a matter of tenths of mm, so that is indeed a very small measurement.
If there was an easier method to communicate with mw, it would be great. meanwhile, I will switch the units when I run into this sort of trouble!
thanks again
wim
6442.8 In reply to 6442.7
Hi wim,
> units is a pain.
You can solve this one by setting the option in MoI under Options > Import/Export > OBJ options > "Scale factor". If you put in 0.01 for that scale factor option, your exported OBJ file will get scaled down by 1/100 in size just at export time, that should get it at the size that Maxwell likes to have things.
This is really the best way, because if you post here there is a chance that someone else may be able to help if I'm away on some family emergency like I am now.
Thanks, - Michael
Show messages: All  1-6  7-8
