Javascript performance issue
All  1-5  6-8
6440.6 In reply to 6440.4
Nice looking results, Max!
I have some ideas for the future on how to try and make "out of process" scripts run faster, something like move objects that the script wants to access over into the worker process so that the script can have local access to them, and then after the script has done all its processing work move the results back into the main process. That's basically how an async "geometry factory" works right now but with C++ code.
6440.7 In reply to 6440.6
Thank you, Michael!
>>.. like move objects that the script wants to access over into the worker process so that the script can have local access to them..
Very good idea! It will really help.
I checked the performance and found that the bottleneck in my script are getStartPt and getEndPt functions (only 900 segments per second, while script can process about 1500 segments per second).
The overall performance is ~600 instances per second.
Tomorrow I will move some functions to htm file.
6440.8
Unbelievable!
I've got more than 10x boost!!
Normal mode:
Without 3D transformations:
EDITED: 7 Mar 2022 by SMIRNOV
Show messages: All  1-5  6-8
