Javascript performance issue
All  1-3  4-8
6440.4 In reply to 6440.2
>>any script code that's declared in the .htm file will run in the main process too
Great!! Thank you for the hint! Now it works very fast.
I am writing script which generates multiscatter data for Octane render. It's very handy to use MoI for this purpose. But I need to process huge amount of data in short time (100000 - 300000 points). Now it will work even faster than before. :) I'll finish it in couple days.
This is a test renders. Both scenes created in MoI. I spent 30 minutes making this.
First one: 6 objects, ~10000 instances. Second: 1 object, ~7000 instances.
EDITED: 7 Mar 2022 by SMIRNOV
6440.5 In reply to 6440.3
Brian, thank you.
Sometimes I used this trick before, but I never thought about performance differences.
P.S. And thank you for your scripts! :)
I used Harmonic Trefoil script in this test.
6440.6 In reply to 6440.4
Nice looking results, Max!
I have some ideas for the future on how to try and make "out of process" scripts run faster, something like move objects that the script wants to access over into the worker process so that the script can have local access to them, and then after the script has done all its processing work move the results back into the main process. That's basically how an async "geometry factory" works right now but with C++ code.
6440.7 In reply to 6440.6
Thank you, Michael!
>>.. like move objects that the script wants to access over into the worker process so that the script can have local access to them..
Very good idea! It will really help.
I checked the performance and found that the bottleneck in my script are getStartPt and getEndPt functions (only 900 segments per second, while script can process about 1500 segments per second).
The overall performance is ~600 instances per second.
Tomorrow I will move some functions to htm file.
6440.8
Unbelievable!
I've got more than 10x boost!!
Normal mode:
Without 3D transformations:
Show messages: All  1-3  4-8
