Straight loft problem with more than 2 profiles
All  1  2-3
6431.2 In reply to 6431.1
Hi Supagoat, thanks for posting the file to reproduce this - it looks like a bug in the surface splitting mechanism, the way straight sections loft works internally is that it builds a long surface that has kinks in it and then splits it up, it seems that one piece is not getting split as it should.
Tommorrow I will take a closer look into the splitting mechanism to see some more details about the bug and investigate what's involved in fixing it.
Thanks, - Michael
6431.3 In reply to 6431.1
It lofts in straight mode if selection is done from big to small rectangles, left to right in 3d view.
Incorrect loft occurs if selection is from right to left.
It lofts ok if the middle size rectangle is moved away enough from the large rectangle.
Show messages: All  1  2-3
