classic rotate, scale, translate widgets?
All  1-2  3-4
643.3 In reply to 643.2
I was wishing MOI had those 3D manipulators the other day as well...
Being able to move, scale or rotate without starting a "formal command" I believe would be much faster for a lot of stuff.
I do like the idea you mentioned, Michael about the Illustrator type "object boxes".
-Will
643.4 In reply to 643.3
Actually, one of those - moving - is available now, just click and drag on an object to move it. You only need to use the formal Transform/Move command for some more specialized situations like moving by a displacement snapped on to some specific points.
Scaling and rotating are the missing quick ones right now...
(I bet you probably knew this, just wanted to clarify for others).
Show messages: All  1-2  3-4
