Hi Max, this is probably history data, when you run commands a record of all the inputs that went into the command is stored on output objects. With some commands (ones that run asynchronously in the worker process) there is a problem where if it is used with a large quantity of objects each output history record is ending up containing the records for all the input and output objects and so that ends up taking up a lot of space.
It's the same issue that was recently reported here when doing Construct > Planar on a large amount of objects:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6412.1
Right now you can solve this by selecting the objects and running a script to purge the history data off the objects, see here for the script to set up:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6029.2
If you select your objects and run that script it should slim down your file when you save it after that.
I've recently been looking into this problem and I hope to have it solved for the next beta. The specific problem is that on geometry factories that run asynchronously the more granular relationship information between an individual input and an individual output is being lost.
> I think MoI saves to file information about last transformation. Do we need it?
It's information that is stored on output objects, about how they were created. You don't need it if you are not going to be using history updating on those objects.
> And another question. Is there any command which I can use in script to
> enable/disable undo, or clean all undo data?
There is nothing for scripting that currently, but you can set some limits that control undo in moi.ini, under:
[Undo]
MaxMemorySizeMB=20
MinNumberOfUndos=10
If you're working with heavy files you may want to reduce the minimum number of undos to be lower than the default.
The undo system will store at least as many steps as given in the min number option, and as many more than that as will fit in the maximum memory size.
