Harmonic Trefoil
Here is another Trefoil, which seems to have a "nicer" shape than the torus knot trefoil.
Formula from here: http://virtualmathmuseum.org/SpaceCurves/trefoil_knot/trefoil_knot.pdf
6425.2 In reply to 6425.1
Came across the figure8 knot, also from Aaron Trautwein, who also has a book, so I added it into the trefoil script.
It looks like a lot of numbers were adjusted slightly to two decimal places, to get a "pleasing" curve.
There is one too many points in the point version, so the index still needs to be modified slightly.
I guess the curve factory version is OK with respect to the "extra" point.
Also the pointfactory should not be created outside the loop, in some prior point scripts...
Cool!
6425.4 In reply to 6425.2
Brian,
I thought that might like to know that your script (for which many thanks) has resulted in a least one 'non-virtual' artefact: http://www.thingiverse.com/thing:1955925
Mike.
Size: 197.2 KB, Downloaded: 55 times, Dimensions: 1200x933px
6425.5 In reply to 6425.4
That is cool Mike!
- B
