Hi Metin,
> I also discovered that you can change the radius indication / value to diameter by default in the .ini file.
Yup! Just in case anyone else reading this is looking for this same thing, it's a setting under the [Commands] section of the moi.ini file:
[Commands]
UseDiameterDefault=n
If you switch that to =y then commands that have a switchable radius/diameter input in them (like circle or sphere for example) will default to diameter instead of radius.
