Drawing as background image
All  1-11  12-15
6417.12 In reply to 6417.9
Hi Axel, I'm glad that changing that setting helped you too!
> For unfolding I will use Rhino4, I hope the dimensions will be copied from MoI.
Yeah, there is a high degree of compatibility from MoI to Rhino, you can bring in anything you create in MoI into Rhino without disrupting sizes or things like that. You can also use Copy/Paste to move objects back and forth between MoI and Rhino as well.
> For a future update or version 3, would it be possible to show the actual
> length for curves, not only the radius?
There isn't too much room to put a lot of information into the top level properties panel, but in the future I do want to make an "extended properties" dialog box that you could pull up that would then have a lot more details available on it.
And the "UnwrapCurve" script will yield a line with the length of the curve.
6417.14 In reply to 6417.13
You can find UnwrapCurve here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5136.1
6417.15
I usually use http://kyticka.webzdarma.cz/3d/moi/#CurveLength to get a curve length.
Show messages: All  1-11  12-15
