Point select mode, merge surfaces, re-parametrize
6415.1
Hello
First of all, thanks for this beautiful piece of software. Well now a few questions.
1: any chance to have "component mode" in MOI, similar to DCC apps. Mode which allows manipulation of points and nothing else. When tweaking points, I found somewhat hard to avoid the incidental move of other, unwanted objects. Dragging from the left towards the right helps a bit, but not completely. Hiding the faces helps a bit more, but then I have no visual feedback.
2: merge surfaces: any way to do that in MOI. I mean, just simple point-to-point merge ( not some complex re-sampling mechanism) let's say if I want to merge the mirrored copy of object - even on price of changing the shape in merging area.
3: re-parametrize surface or curve: any way for this MOI. Here I'm considering the method in Softimage or Maya, where, "uniform re parametrization" acts similar to morphing of uniformly distributed grid, with same UV point count, to another, curved surface. I've tried to misuse the "flow" command for this purpose, but it seems that "flow" don't want to go in this simple way ( simple way = no re - sampling). Yeah I read on this forum, that point tweaking is not preferred way in MOI. Anyway, if already is possible to tweak points, together with all that nice snapping options - there should be a way to avoid the strange curvature, as result of some heavy re-positioning of points.
And.... finally, is there any :) construction operator in this software, which does not perform all that rebuilding, re-sampling, whatever.. under the hood. It takes me a good time to get familiar with these behaviors.
6415.2 In reply to 6415.1
Hi Anto, I'm glad that you're having fun with MoI!
Right now control point modification of surfaces is just not a big focus area for MoI - I sort of assume that if you need to be doing that kind of work you'd be doing it in a polygon modeling program rather than in MoI. The focus in MoI is much more on things like booleans and a workflow using 2D curves, not so much on 3D surface control point sculpting, although in the future I would like to add some more stuff to that area as well. But just in general NURBS surfaces are not really that great for high detailed control point editing type of a modeling strategy because you can't add a single point anywhere you want, a NURBS surface is always made up of a regular row and column grid.
You can use Edit > Join to glue 2 surfaces together at a common edge but the result there will be a set of 2 faces that have a joined edge between them, not a single surface. A surface merge function is also something that I want to add in the future, but again it's part of a surface control point editing workflow which has just not been a focus area yet.
I think you mean a "rebuild" command that samples points on an existing surface and constructs a new one through those sampled points? There is a rebuild command but it currently only works for curves, not for surfaces:
http://moi3d.com/2.0/docs/moi_command_reference10.htm#rebuild
Once again, that's part of a surface control point editing workflow and that's just not really the main construction method that MoI is primarily targeted at right now.
The strong areas of NURBS modeling are more in making large portions of your model from 2D curves, using some from construction and some for cutting operations. Control point tweaking is just not as productive with NURBS surfaces as it is for sub-d modeling so I haven't really focused much attention on that area since it's just not the strong area of NURBS and there are already so many sub-d modeling programs out there which are focused on that type of method.
Sorry I don't understand this question. There are various construction methods like sweep, extrude, revolve, loft, etc... which are able to build surfaces from curves... And also boolean operations which can also cut solids by curves as well. It's more intended that you would use this curve-driven method for constructing things in MoI and not so much a surface point editing sculpting-like technique like you're trying to use right now.
6415.3 In reply to 6415.1
One note that may help you with some point selection though - if you hold down both Ctrl + Shift, that will force window selection mode when you click and drag, meaning that you don't have to click in an empty area to start the window when both of those are down, things won't get selected by the starting click when you have those down it just goes straight into window selection mode.
6415.4 In reply to 6415.2
> I think you mean a "rebuild" command that samples points on an existing surface and constructs a new one > through those sampled points? There is a rebuild command but it currently only works for curves, not for > surfaces:
Well I meant something like in image. Selected one is exported as IGES from MOI, uniformly re - parametrized in Softimage, imported back into MOI. Points are on the same position, but shape is different, after Softimage re - parametrization. But it doesn't matter - exchange via IGES seems to works perfectly on MOI - Softimage route, so I can do this in Softimage.
I had to do some structure, where is really hard to define the volumes and blends between them, but also a lot of small details, impossible to do with Softimage's ancient NURBS tools- and it will take ages to with polygons. So it seems everything I want is available.
Please forget mu beginner's impression about 're- sampling everything'. Long time ago I've played a lot with Rhino beta, but everything I learned later belongs to DCC world, where keeping the point IDs seems to be more important than keeping the accurate shape.
Thank You kindly for your time, again.
6415.5 In reply to 6415.4
Hi Anto,
> the same position, but shape is different, after Softimage re - parametrization. <...>
I see, so I guess what Softimage is doing in that case is throwing out what is called the "knot vector" part of the NURBS structure and instead creating what is called a "uniform knot vector" which basically means every control point has the same amount of influence on the spline shape.
But that's a sort of unusual thing to do with NURBS surfaces really, because as you mentioned it can cause the surface shape to mutate, sometimes in fairly odd lumpy bunched up ways if the original surface had a lot of non-uniform knot distribution...
Most of the time with NURBS surface modeling there is much more of an emphasis on preserving the shape of the curve or surface itself to some tolerance level rather than trying to preserve the particular position of the control points.
Maybe I could help you some more if I understood the particular reason _why_ you want to use this Softimage function on your surfaces to begin with... What is it that you're looking to gain by doing that?
The main focus for MoI for control point editing is to do that on curves, not really on surfaces. Once you have got some curves drawn and edited, then when you create surfaces from those curves it tries to make those generated surfaces be accurate to follow the overall shape of the curves. Some operations like intersections and sweeps work by an iterative refinement method where they add as many control points as needed to the generated curve in order to achieve a certain level of accuracy to the desired "ideal" shape. With that overall workflow, the specific arrangement of surface control points isn't really all that important, it's more about viewing the surface as a sheet of geometry that you know follows your profile curve shapes to a high level of accuracy.
And yes, this whole workflow is indeed quite different from the 3D point control-cage-focused type process that you'll be focused on with a polygon mesh modeler.
In a sub-d modeler, the process is kind of more like sculpting in a way, where you're doing a lot of squishing of points around on the 3D shape. MoI is designed with a pretty different workflow in mind from that, in MoI it's sort of more like illustration rather than sculpting, where you focus more on drawing 2D curves to define key profiles of the shapes, and then surfaces are generated directly from those profiles and not really squished around themselves directly in 3D.
The MoI workflow tends to work very well for man made objects that are often times well defined by 2D profile curves. By being able to do most of the work in 2D these kinds of shapes can be constructed very rapidly with MoI's main intended approach.
For shapes that are more lumpy organic type things, those are usually not very well defined by 2D profile curves and those type of shapes are usually better to do in a sub-d modeler instead of in MoI.
There is some limited amount of 3D surface control point squishing in MoI as well, but it's not really primarily designed to do things that way.
6415.6
Anto,
Point 1 and 2 would be my number 1 and 2 feature requests for MoI also, they would both be extremely useful features to have.
~Kevin~
6415.7 In reply to 6415.5
It's not only that. Actually I already have a small set of tools for attaching the NURBS grids to portions of mesh subd hull, mainly used for "unusual" purposes, like rigging, hair styling, emitting particles, so on. Something like "poor man T-Spline". From my understanding, if NURBS grid is attached to arbitrarily shaped, quad like mesh structure, it acts like "uniform". By the way, Maya has exactly the same function, with same name.
This time, as I have to stop with experiments. It's much easier to me, to attach these NURBS grids in Softimage, to existing mesh, then to export IGES to MOI for adding details - instead of finding curves on it. It's space ship model for use only in DCC app, accuracy doesn't matter. It's not what we consider as "organic".
Next time I hope I'll be able to do everything in MOI.
6415.8 In reply to 6415.7
Hi Anto,
I'm not sure if this is what you mean, but yes a totally regular quad mesh structure using sub-d modeling will behave the same as a uniform NURBS surface.
But I don't really understand why you wouldn't just use sub-d objects for these various things that you mention, like hair styling for example.
The main area where NURBS surfaces have benefits compared to sub-d meshes are when it comes to booleans and cutting operations. But you're probably not using stuff related to booleans when doing hair styling... ?
Just in general MoI itself is not focused on generating things for squiggly jiggly type stuff, it's more about building mechanical man-made objects (where booleans and 2D curve driven modeling is very useful) which are usually just animated with movement and rotation, not arbitrary squashing around.
6415.9 In reply to 6415.8
NURBS surface provides always present UV space, perfect interpolation as well. Generally it's much easier, and faster, to use NURBS for any kind of defining the custom, deformable, 3d cord system.UV as XY, normal as Z, or like. Usually there's built - in constraint to NURBS surface, deforming operator that works in similar way to MOI flow, so on. Getting the same form SUBDs, takes more effort, means much slower computation time. For example, Softimage applies SUBD interpolation, always as last operator, after computation of collisions or distance queries - so it's more a display/ rendering feature, not something to use for interaction. But NURBS is taken fully interpolated, all the time.
There's traditional "Maya ribbon spine" rigging setup which utilizes NURBS surface: http://www.creativecrash.com/maya/tutorials/character/c/ribbon-spine-rig
Here is one small hair styling system created by me: http://area.autodesk.com/tutorials/mars_police_hair_and_render_breakdown. Here, polygons were used only as hulls for tweaking, only because Softimage has much better tool set for polygon tweaking.
Yes, almost all setups of this kind, utilizes single, open NURBS surface, or bunch of them. So built in tool set is more than enough.
Anyway, I bought MOI for modeling, as I noticed that with polygons, about half of modeling time (or much more) goes onto preparing the geometry for adding the details.
There is also individual approach, how someone visualizes the forms. Having a zero experience with CAD modeling, I'd visualize, for example, bottle as modified cylinder, house as bunch of boxes. Not as revolution along axis or extruded plan. But that's just me :).
EDITED: 8 Jan 2014 by AMM
