Lorenz Attractor Script?
All  1-3  4-18
A quick draft. Needs some work.
Oh, that was quick Brian! :-) Thank you very much. It's really nice that the user can set also the number of point!
Best regards
6403.6 In reply to 6403.5
i like to ask if the script can be further enhanced so that it accepts equations too, to generate other Attractors?
I'm not sure if this is possible with MoI scripts , so just asking, if not i guess i can use your original script and
insert there other equations???
Best regards
6403.7 In reply to 6403.6
I am an amateur programmer, with limited abilities.
A program like k3dsurf allows the entry of equations.
So a better programmer might be able to create a program to allow equation entry.
I have come across dozens of dozens of other attractors. Perhaps there are an infinite number?
For example, the Aizawa attractor has 6 parameters, a,b,c,d,e,f. Yet it still has 3 simple equations.
So these additional parameters could be added to the htm file.
http://jlswbs.blogspot.com/2011/10/aizawa.html
Alternatively, the code could be created to allow selection of pre-programmed attractors from a list. I was thinking of asking Michael how to do this in code, but one should first make an effort?
For example, to create a circle in MoI, first the circle command is selected, then another selection pops up to allow the choice of which type of circle
to create.
I started to add lineweb code to add a point output option, but ran out of energy that night :-)
Also thought about allowing the user to enter start points, or have 3 more inputs, x,y,z start points entry...
EDITED: 6 Jan 2014 by BEMFARMER
Seems Chaoscope above have all common attractors! ;)
6403.9 In reply to 6403.8
@Brian - Thanks for the reply! I may check then the script and see what i can do.
@Pilou - Well, you can't save splines and process them in MoI, right…
Best regards
6403.10 In reply to 6403.9
<< Well, you can't save splines and process them in MoI, right…
Sure but you have all the formulas! ;)
http://www.chaoscope.org/manual.htm
Did an upgrade to the script, to version 2, with minimal testing.
Added optional ability to plot points, with code borrowed from Lineweb script.
Also entries for x,y and z, which cannot all be zero.
6403.12 In reply to 6403.11
Did you forget to attach version 2?
Strange indeed! :)
6403.14 In reply to 6403.12
Well, it was late.
Excellent! Bravo!
A little trick : make the reseach of parameters inside Chaoscope then apply them inside moi!
That will be more speady! ;)
Here I make the inverse because the Moi parameters were yet calculated! ;)
same parameters inside Chaoscope!
Elegant! :)
Sweep a circle then Twist and Array / Circular
EDITED: 10 Jan 2014 by PILOU
6403.17 In reply to 6403.16
Cool effect. :-)
Peace,
Rich_Art. ;-)
6403.18
I love all these scripts! :-)
Thank you so much!
I created another image for my website, this time based on a Lorenz Attractor ;-)
http://www.screendream.de
Cheers,
Tom
Show messages: All  1-3  4-18
