stl question
All  1  2-4
640.2 In reply to 640.1
Hi Graham, that's correct MoI will not open STL files, only export them.
That's because STL files contain a different type of object than what MoI normally works with - MoI works with smooth surfaces which is a technology called "NURBS", while STL files do not contain smooth surfaces, instead they contain a bunch of faceted triangles.
MoI can convert from a smooth NURBS surface into a triangulated mesh, but it is not very easy to go from a triangulated mesh back into a smooth NURBS surface.
It's kind of like how you can make apples into applesauce, but it is not easy to take applesauce and make it back into apples again...
640.3
so iguess i should have saved it as somthing eles till i was fineshed the model. guess ill start over, it was just a small model any way, Thanks michael. Graham
640.4 In reply to 640.3
Hi Graham, yeah definitely don't save your final "real" version as an STL - you generally want to save your main data file as a .3dm and only use .stl as a type of conversion export into some other program.
Show messages: All  1  2-4
