Hard surface simulation software
All  1-5  6-8
6399.6 In reply to 6399.3
Hi Yakas,
Very similar to what Michael mentioned (2d Working Model) only this one is free it's called Algodoo http://www.algodoo.com and I think you can import accurate shapes, not sure, you'll have to check it out.
6399.7
Thanks everyone,
Algodoo is perfect! Very simple yet useful.
6399.8 In reply to 6399.7
there is something called dxf2phun, which should convert a dxf file into an algodoo readable.
http://en.sourceforge.jp/projects/dxf2phun/
it's a pretty straight forward, drag&drop application. the output is a script(thyme), which you can paste into algodoo (shortcut F10 in algodoo brings down the console window). i did use it with some older versions of algodoo, but as i can recall, dxf2phun is quite picky regarding the geometry it's been fed. i had more luck with svg2phun
http://www.geocities.jp/int_real_float/svg2phun/SVG2Phun.html
via. uniconverter(ai to svg), as there is no native SVG export option in MOI.
http://sk1project.org/modules.php?name=Products&product=uniconvertor
Show messages: All  1-5  6-8
