Hi everyone,
Does anyone have any suggestions for a mechanical hard surface simulator that is comparable to moi in usability and simplicity? I only need movements to be animated.
I would like to visualize mechanical movements such as how a cam will affect other moving parts. I just want to select a part, pick it's axis of rotation and see how it interacts with other parts. Very basic stuff.
Very similar to what Michael mentioned (2d Working Model) only this one is free it's called Algodoo http://www.algodoo.com and I think you can import accurate shapes, not sure, you'll have to check it out.
it's a pretty straight forward, drag&drop application. the output is a script(thyme), which you can paste into algodoo (shortcut F10 in algodoo brings down the console window). i did use it with some older versions of algodoo, but as i can recall, dxf2phun is quite picky regarding the geometry it's been fed. i had more luck with svg2phun
