[script] Morph between two curves
1-20
21-29
Frenchy Pilou (PILOU)
20 Dec 2013 (21 of 29)
6373.21
Cool plugin but something curious! :)
Line Web:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3666.10
So it's you or Michael who have made an inversion! :)
I presume it's you for any secret reason! :)
(not a big deal as the Flip Command exists in Native in Moi : just select a curve(s) and Press Tab then type Flip! :)
I first use CMorph between the 2 yellow curves then LineWeb! Careful! Order of select curves is important for LineWeb!
EDITED: 20 Dec 2013 by PILOU
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
archetype (FABIENF)
20 Dec 2013 (22 of 29)
6373.22
It works, thanks Max! Only thing left now is the flipped curve direction as Pilou mentions.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Max Smirnov (SMIRNOV)
20 Dec 2013 (23 of 29)
6373.23
In reply to
6373.21
Ops. Just forgot to check this :)
Found. Fixed. Uploaded.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
20 Dec 2013 (24 of 29)
6373.24
In reply to
6373.23
This is really cool Max, thanks for posting it and updating it!
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
29 Dec 2013 (25 of 29)
6373.25
Cool! ;)
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
jopo
21 Mar 2018 (26 of 29)
6373.26
Hello Max
in Moi V4 on my Mac I get this error message when I run the script. In V3.1 it's working fine.
cheers
jopo
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
21 Mar 2018 (27 of 29)
6373.27
In reply to
6373.26
Hi Jopo
you need to download a latest version of the script:
http://moi.maxsm.net/files/scripts/cMorph.v.1.1.2014.01.19.zip
moi.maxsm.net
scripts archive
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
jopo
24 Mar 2018 (28 of 29)
6373.28
In reply to
6373.27
Hi Max,
thanks a lot! It's working now.
JoPo
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
TheFlow
10 Mar (29 of 29)
6373.29
I'm usually not very active here but I had to tell you: THANK YOU! This helped me save at least an hour of work!
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
21-29
